Finding internal resistance
  • Thread starter arkofnoah
http://img408.imageshack.us/img408/6537/screenshot20100808at134.png [Broken]
I redrew the circuit as follow:
http://img293.imageshack.us/img293/6247/screenshot20100808at135.png [Broken]
Is this correct (or even useful in the first place)?
Anyway when switch S1 is closed, the total resistance = rx + ry, the internal resistances of the batteries.
But when both switches are closed, I figured that the voltage increased by 0.02V, to 0.07V. However I am not sure this is the voltage across which components because the millimeter is connected in a rather strange way.
I'm lost from here onwards. I'm mostly troubled by the placement of the millivoltmeter I guess.
Am I on the right track? Any alternative method?
The answer is (A) by the way.
Answers and Replies
ehild
15,543
1,914
The ideal millivoltmeter has infinitely high resistance.
ehild
okay i was thinking about that. when switch 1 is closed there is no current, and when both switches are closed the entire circuit system is basically a series circuit because no current flows though the millivoltmeter.
but i don't know what is the implication of this :tongue: what does the 5.0mV mean? what does the change of 2.0mV mean? any clue?
ehild
15,543
1,914
When S2 is open the branch wit R just does not exist. Draw this arrangement. It might help. The voltage of what does the voltmeter read?
ehild
alright. so 5.0mV would be the potential difference between the two cells. Since there is no current flowing this is equal to the emf difference between the two cells, correct? so i can effectively treat X and Y as if it is a single cell with emf 5.0mV, right?
when s2 is closed, will the voltage increase by 2.0mV or decrease by 2.0mV? i know there is now current flowing in the branch with S2 but can you elaborate how exactly does this affect the millivoltmeter reading?
Oh okay i think i get it. So initially the voltmeter reading of 5.0mV is
[tex]E_{x} - E_{y}[/tex] where Ex and Ey is the emf of X and Y.
Now after closing the circuit with R, current flows through the internal resistor of X and the voltmeter reading of 3.0mV is
[tex]V_{x} - E_{y}[/tex] where Vx is the terminal p.d. of X, which is lower than Ex its emf.
The difference of these two is basically
[tex]E_{x} - V_{x} = Ir[/tex] where r is the internal resistance of battery
So 2mV = 5.0(r) and r is 0.004 ohm.
Am I correct?
ehild
15,543
1,914
Perfect, except two minor errors: The first voltage reading is 50 mV and the other one differs from this by 20 mV.
From 2 mv =r (5 A) --->r = 0.0004 ohm, but you get the correct result if you use the original 20 mV. :biggrin:
ehild
oh okay that's more of a typo :tongue:
thanks for your help!!
Related Threads on Finding internal resistance
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
