Finding limit at infinity
  • Thread starter physics604
physics604
92
1. Evaluate lim x[itex]\rightarrow[/itex]-[itex]\infty[/itex] [itex]\sqrt{x^2+x+1}[/itex]+x.The answer is -[itex]\frac{1}{2}[/itex].
None.
I multiplied by the conjugate first, so it turns into
lim x[itex]\rightarrow[/itex]-[itex]\infty[/itex] [itex]\frac{(x^2+x+1)-x^2}{\sqrt{x^2+x+1}-x}[/itex]
= lim x[itex]\rightarrow[/itex]-[itex]\infty[/itex] [itex]\frac{x+1}{\sqrt{x^2+x+1}-x}[/itex]
I divide by 1/x on the top, and 1/√x2 on the bottom.
lim x[itex]\rightarrow[/itex]-[itex]\infty[/itex] [itex]\frac{\frac{x}{x}+\frac{1}{x}}{\sqrt{\frac{x^2}{x^2}+\frac{x}{x^2}+ \frac{1}{x^2} }-\frac{x}{x}}[/itex]
= lim x[itex]\rightarrow[/itex]-[itex]\infty[/itex] [itex]\frac{1+\frac{1}{x}}{\sqrt{1+\frac{1}{x}
+\frac{1}{x^2}} -1}[/itex]
At this point, this is all the algebra I can do. So now I have to plug in the -[itex]\infty[/itex].
When x goes to -[itex]\infty[/itex] into [itex]\frac{1}{x}[/itex], I get 0. Same with [itex]\frac{1}{x^2}[/itex], I also get 0.
So wouldn't that make my equation
[itex]\frac{1+0}{(√1+0+0)-1}[/itex]? My answer would be undefined then, not -[itex]\frac{1}{2}[/itex]...
Answers and Replies
Dick
26,263
619
None.
x is NEGATIVE. If that's the case then sqrt(f)/x=(-sqrt(f/x^2)). Think about examples with numbers.
physics604
92
Yes, but how does that apply to my equation?
physics604
92
Even if x is negative, [itex]\frac{1}{x}[/itex] would be so small that it would be insignificant.
Dick
26,263
619
You are screwing up a sign with x being negative. You should be getting 1/(-1-1). The sign on the square root is wrong.
Dick
26,263
619
No idea what you are talking about. (-1)*sqrt(2) is -sqrt(2*(-1)^2). It's not sqrt(2*(-1)^2).
physics604
92
I think my algebra is right. What step did I do wrong?
Dick
26,263
619
Your algebra is right if x>0. Your algebra is dead wrong if x<0. I've told you.
Office_Shredder
Staff Emeritus
2021 Award
5,083
1,093
When you divide by 1/x on the top, and [itex] 1/\sqrt{x^2}[/itex] on the bottom you have multiplied your expression by -1.
Dick
26,263
619
And you also converted ##1/\sqrt{x^2}## into 1/x when you multiplied the second term. They just plain aren't equal.
physics604
92
Okay, thanks I got it.
Suggested for: Finding limit at infinity
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
