Calculating Mass using F=ma and Friction
  • Thread starter Drew552
  • Tags
    F=ma Mass
In summary, the student is trying to find the mass of an object pushed on a horizontal surface by 500N of applied force, and is not sure how to find the coefficient of friction. The student has been given the friction force and the weight of the object, so they can calculate the coefficient of friction. Once they have the coefficient, they can use it with the friction force to calculate the mass of the object.
Drew552
Well i have the force which equals 500N and I don't have a given acceleration so should I be substituting 9.81 as the acceleration? or is their another way to find it given that I also have the friction which equals 125N. So which way is the right way of going?
F=Ma
Well what I've done is 500=m x 9.81, which goes to 500/9.81=m, which then gives me 51.02kg, so is that correct because it doesn't seem right to me.
Any help would be much appreciated,
Thanks.
Can you please state the exact problem you are asked to solve, word for word.
Its a fill in the chart question so its not really a word for word one, i have all the values but this one. If i can provide anything else please tell me.
You need to describe the situation a bit more. You have the force on what? What is it doing?
Well its on a friction simulator online. I'm pushing on a unknown mass with 500N of applied force. The friction force comes out as 125N and the sum of the forces is 375N to the right direction. I am asked to find the mass and the weight of the object. I want to know the mass of the object which in turn will let me work out the weight with W=mg.
Thanks.
OK. Across a horizontal surface?
So the only horizontal forces involved are the applied force and the friction?
Are you given any additional information? Such as the acceleration or the coefficient of friction?
Yes it is being pushed on an horizontal surface. And yes the only horizontal forces are the force and friction. No i am not given the acceleration but I am assuming it could possibly be 9.81 and it doesn't give me the coefficient of friction.
That's the acceleration due to gravity. No reason to think the mass has that acceleration.
I do not see that enough information has been given to solve the problem. Does the diagram or chart have any other info in it? Or a previous problem?
Am i allowed to attach a picture of the chart and also the picture of the simulator??
Go ahead.
So you have plenty of other info! Hint: Use the data for the other masses to figure out the coefficient of friction. (In fact, if you understand the chart, you don't even need to calculate the coefficient. You can just read off the mass that you need.)
I do? Well point taken then, thanks for the hint, ill try to to do my best at getting the answer but still unsure how to get the friction coefficient
Hint: What's the basic relationship for kinetic friction that uses the coefficient of friction?
F(kinetic)= u(coefficient) x F(normal)??
Exactly! And in these examples, what creates the normal force?
a entity pushing against something thus making the kinetic energy?
so if i had a 20N force pushing a against a box the normal force would equal 20N right?
The normal force is the force pushing each mass against the surface. What is that force?
The force is the 2 entities rubbing together?
Sure, but what supplies that force? It's not the applied force, since that force is horizontal. Hint: What's the only vertical force acting on the masses?
gravity?
Drew552 said:
gravity?
Of course!
Now pick anyone of the masses and use the given data to figure out the coefficient of friction (which is a constant for this problem).
so it would be 40=u+9.8 Assuming 40 is the mass
so is the coefficient of friction constant over one horizontal surface no matter the mass?
Yes, assume for this problem that the coefficient of friction is constant regardless of mass. (Meaning: Assume the masses are all the same material.)
Pick one of the masses that are given. Find the normal force, which is just the weight. You are given the friction force. Use those values to calculate the coefficient.
Once you have the coefficient, you can use it with the friction force to calculate the unknown mass.
Ok, thank you for all your help, I think I've got it down now. ill post again if i come to any complications.
Thanks a lot :)
1. How do you calculate mass using the formula F=ma?
The formula F=ma states that force is equal to mass multiplied by acceleration. Therefore, to calculate mass, you can divide the force by the acceleration.
2. What is the unit of measurement for mass in the F=ma formula?
The unit of measurement for mass in the F=ma formula is kilograms (kg).
3. Can the F=ma formula be used to find the mass of an object in any scenario?
No, the F=ma formula can only be used to find the mass of an object if the force and acceleration are known. It cannot be used to find the mass of an object in scenarios where these values cannot be measured.
4. What are some real-life applications of the F=ma formula?
The F=ma formula is commonly used in physics and engineering to calculate the mass of objects in motion, such as in the design of vehicles and structures. It is also used in sports to analyze the movements and impacts of athletes.
5. Is the F=ma formula always accurate in calculating mass?
No, the F=ma formula is based on Newton's second law of motion, which assumes that the force and acceleration are constant. In real-life scenarios, these values may vary, leading to some inaccuracies in the calculated mass.
