How to find oblique asymptotes for any function in general?
  • Thread starter benji
In summary: In summary, the conversation discusses the process of finding an oblique asymptote for a given problem. The speaker is having trouble with the process and is unsure where to start. They question if they need to factor the numerator, but it comes out as an imaginary number. Another speaker suggests using polynomial division to write the function in the form of a quotient plus remainder over the divisor. They explain that the oblique asymptote will be the quotient. The conversation also touches on the concept of oblique asymptotes and how they relate to the behavior of a function as x approaches infinity. Finally, there is a discussion on different methods for
benji
48
I'm having trouble figuring the oblique asymptote for this problem...
I haven't ever done one of these before so I really don't know where to start.
Here's the problem:
y=(2x^2+5x+11)/(x+1)
http://home.att.net/~srschmitt/precalc/precalc-12-03-00.html
Hmm... I'm still not quite getting it.
I need to factor the numerator then, correct? But it comes out as an imaginary number?
You only need to do the polynomial division, so you can write it in the form of Quotient + Remainder/Divisor, because of Euclides Algorithm Numerator = Quotient*Denominator + Remainder.
The Oblique Asymptote will be the quotient.
The whole point of oblique (or horizontal) asymptotes is "what happens as x goes to infinity or negative infinity?"
With something like [tex]y= \frac{2x^2+5x+11}{x+1}[/tex] the simplest thing to do is to divide both numerator and denominator by the largest power of x in the denominator- here just x. [tex]y= \frac{2x+ 5+ \frac{11}{x}}{1+ \frac{1}{x}}[/tex]. Since those fractions with x in the denominator will go to 0 as x goes to either positive or negative infinity, it's easy to see that y approaches 2x+ 5.
I had an oblique asymptote question on my Calc I exam and I totally forgot how to do that. What I eventually did was to get an equation for the tangent at the point (a,f(a)) and then let a approach infinity, figuring that the tangent will coincide with the asymptote in that limit. Although I felt pretty good after coming up with that idea at the time and the answer was correct, I still received a big red cross through my solution :(
Just pointing out something...I know it's a really old thread !Someone pointed out earlier that for something like [tex]y= \frac{2x^2+5x+11}{x+1}[/tex] you can just divide by "x" and get that the asymptote is: [tex]y= \frac{2x+ 5+ \frac{11}{x}}{1+ \frac{1}{x}}[/tex]
However, that is not the case I believe. The asymptote is actually 2x+3, and it is found by:
= Lim x -> infinity, f(x) - (mx+b) = 0
So I would do long division, get : 2x + 3 + 8/(x+1) and then use the formula mentioned above:
= lim x-> infinity of 2x + 3 + 8/(x+1) - (2x+3)
that's equal = 0, hence the mx+b part is an oblique asymptote. Which is, 2x+3 = oblique asymptote in this case.
Hope this helps!
Hi, dale 123...you can check your answer by graphing it. Use a program if you're having trouble with the graph. Once it's graphed you'll see that your answer is not right. The correct answer is still 2x+5.
You're both wrong, dale 123 is correct. To find the oblique asymptote, you must use polynomial long division, and then analyze the function as it approaches infinity.
Taking the limit first, like HallsofIvy did, is wrong because 11/x and 1/x approach infinity at different rates, and therefore add to the numerator and denominator in slightly different ways.
If you are not finding the limit at infinity of the entire function, as in this problem, then you MUST write it in the form "term + term + ... + term", and analyze each individual term as x approaches infinity. This is because fractions can do unexpected things when it comes to limits.
Oh, I am so embarassed! When I read my post I thought "wait, that's not right, you divide the polynomial to find the asymptote!". Don't know what I was thinking 5 and a half years ago. Thanks, dale123 and erh5060, for fixing that.
So dividing by the largest power of x works for horizontal asymptotes but not generally for slant asymptotes. That's good to know.
Forgive me; you mean years ago. :wink:
Ahh, yes, of course! I didn't make a mistake- what I wrote clearly must have been true 4½ years ago but not now! :rofl:
There is also a nice way to find oblique assymptotes for any function in general, not only rational functions, since the method described here works only for rational functions.
Let f(x) be sucha function and assume that L=ax+b is the oblique assymptote. Let P be any point in the graph of f and Q be a point in the line L, such that d(P,Q) is the shortest distance. Also let denote by K the point on the line L when we draw a perpendicular segment from point P to the x-axis. Now, after a little bit of geometry we find that L is an oblique assymptote iff
[tex]\lim_{x\rightarrow \infty}(f(x)-L)=lim_{x\rightarrow \infty}(f(x)-ax-b)=0[/tex]
If we divide the whole thing by x, and take the limit we find that:
[tex]a=lim_{x\rightarrow\infty}\frac{f(x)}{x}[/tex]
and
[tex]b=\lim_{x\rightarrow\infty}(f(x)-ax)[/tex]
Likes StudentOfScience
What is an oblique asymptote?
An oblique asymptote is a type of asymptote that occurs when a function approaches a line as x approaches positive or negative infinity. This line is not horizontal or vertical, but has a slanted or oblique shape.
How do you find the equation of an oblique asymptote?
To find the equation of an oblique asymptote, you can use the long division method or the synthetic division method. First, divide the numerator by the denominator of the function. The resulting quotient will be the equation of the oblique asymptote.
What is the difference between a horizontal and an oblique asymptote?
A horizontal asymptote occurs when a function approaches a constant value as x approaches positive or negative infinity, while an oblique asymptote occurs when a function approaches a line with a slanted shape.
Can a function have more than one oblique asymptote?
Yes, a function can have more than one oblique asymptote. This can occur when the numerator and denominator of the function have the same degree, resulting in multiple slanted lines as the oblique asymptotes.
Do all functions have oblique asymptotes?
No, not all functions have oblique asymptotes. Some functions may have horizontal or vertical asymptotes, while others may not have any asymptotes at all. It depends on the behavior of the function as x approaches positive or negative infinity.
  • Calculus
  • Calculus
  • General Math
  • General Math
