• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Finding potential differences
  • Thread starter Pochen Liu
Finding potential difference across a fancy circuit
as attached
In the figure ε = 9.89 V, R1 = 1150 Ω, R2 = 2890 Ω, and R3 = 4940 Ω. What are the potential differences (in V) (a) VA - VB, (b) VB - VC, (c) VC - VD, and (d) VA - VC?
What I've tried
I have derived the equation ε - i1R1 - i2R2 = 0
where i1 is the current running through R1 and vice versa
Questions
How does R3 affect the circuit? I am quit confused as it bridges the parallel lines and I'm now not sure how the current runs
Because I want to find out i1 and i2 such that I can then use:
V = IR
to calculate the Voltage on R1 aka point B
and find VA - VB etc
9,103
The current through which R1?
There is a symmetry you can use but you'll have to discover it first.
The two sides are not identical. In the left path you have the smaller resistance at the bottom (C will have a lower potential than the average of A and D), in the right path you have the smaller resistance at the top (B will have a higher potential than the average of A and D). There will be a current flow through R3.
You don't need to discover this directly. You can calculate VB-VC assuming that no current flows through R3. If it is non-zero (and it will be) then that assumption is wrong.
Delta2
Insights Author
668
you have already made 1 correct equation by applying KVL at the loop ABD+voltage source that contains two unknowns ##I_1,I_2##
Now apply KVL at the loop ACB. The symmetry that @mfb talks about, if you identify it correctly will help you make this equation also with the same unknowns ##I_1, I_2## (and also with the help of applying KCL at node B or node C.
So you ll have two equations with two uknowns, solve the system of equations and you ll know ##I_1,I_2## and everything else can be derived by knowing those 2 values.
Want to reply to this thread?
"Finding potential differences" You must log in or register to reply here.
Related Threads for: Finding potential differences
  • Posted
  • Posted
  • Posted
  • Posted
24K
20K
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
