What Is Oliver's Recoil Speed on Ice After Throwing a Rock?
  • Thread starter grewas8
  • Tags
    Velocity
In summary: The final velocity for the rock would not be zero since it is thrown. Also, you did not take into account the direction of the velocities. Remember, momentum is a vector quantity, so you have to consider the direction as well.Can someone please help me solve this problem?A 60kg teenager on in-line skates intially at rest holds a 0.5kg ball. The teenager throws the ball horizontally at a speed of 12m/s relative to the ground and recoils backwards.Ignoring friction, what is the recoil speed of the skater?As a hint, try using conservation of momentum. The total momentum of the system (teenager + ball) remains constant, so you can set the initial momentum
grewas8
Oliver has a mass of 59.1 kg and can throw a 558.0 g rock with a speed of 19.8 m/s. What would Oliver's recoil speed be if he were on an icy surface?
Momentum is conserved in an isolated system (when Fnet=0 or no external forces are acting on the system)
p=mv
mass(object 1)*initial velocity (object 1) + mass(object2)*initial velocity (object 2)= Mass (object 1)*final velocity (object 1) + mass (object 2)*final velocity (object 2)
m (oliver)= 59.1 kg, m(rock)= 0.588 kg, initial velocity = 19.8 m/s
p(oliver+ rock)= mv
p= (59.1+0.588)(19.8) =1181.8 kg m/s (seems quite too large--> unreasonable?):confused:
on ice (frictionless i assume) no net external forces so Fnet=0
i don't understand what recoil velocity means? Is it the rebound velocity? would be equal and opposite?:grumpy:
***Any help would be appreciated ****:cry:
Realize that Oliver and his rock are originally at rest on the ice. So what is the original momentum of the sytem?
Also, "recoil velocity" is the speed that Oliver will move back with (recoil) after he throws that rock. (If he throws the rock East, he will recoil to the West.)
p(oliver+ rock)= mv
Where is it mentioned that Oliver is traveling at 19.8m/s?
Recoil velocity refers to velocity with which Oliver would be moving AFTER he throws the ball.
Take a look at the equation you posted and just substitute the values.
Would the orginal momentum be zero
so would i use 0 as the momentum and find velocity from there?
i am so confused:confused:
also it says that if oliver throws the rock he would throw it at 19.8 m/s
so is that the velocity at the instant he throws it?
i seem to be more confused..?:grumpy: :cry: :yuck:
Yes, the initial momentum is zero. Before he throws the rock, nothing is moving.
Yes, assume that when he's done throwing the rock, that that is the rock's final speed.
Yes
Yes. Since no external force is said act in the horizontal direction, it would continue with the same velocity.
Okay, I'm late by only 2 minutes this time. :D
Its seems that since that 19.8 m/s is the velocity oliver will continue with, hence that would be the recoil velocity?:confused: :confused: :confused:
But i tried that its not the answer. Ughhh... :cry:
I am going to think about this question later since i should really study for my bio midterm.:!)
19.8 m/s is the speed of the rock, not Oliver. You have to apply conservation of momentum to solve for Oliver's recoil speed.
I seriously dun get this...
Is this wrong?:
(mass of oliver)* (oliver's velocity)= (mass of rock) (velocity of rock)
(59.1)(v)= (0.588) (19.8)
v= 0.588*19.8/59.1
v=0.196?
grewas8 said:
Is this wrong?:
v= 0.588*19.8/59.1
v=0.196?
Yes. In the sense that you forgot a minus sign.
From the origianl equation:
0 = msvsf + movof (s refers to stone and o to Oliver, f - the final velocity)
Therfore,
vof = -(msvsf)/mo
The minus sign is important because you are solving for velocity, and not just speed. The sign says that Oliver would move in the opposite direction with a speed of 0.197m/s.
Hint: Momentum is conserved. What's the total momentum of the skater + ball system?
Can you please show me in steps? and what formula do I use?
It doesn't work that way. You make an attempt, show what you did and where you are stuck, then we'll jump in and help.
As far as which formula to use: See my hint! And read the thread that you chose to hijack! (It's practically the same problem.)
If you have no idea at all about conservation of momentum, read up in your text.
Use m1*initial velocity1 + m2*initial velocity2= m1*final velocity1+ m2*final velocity2
m1= Oliver
m2= The Rock
Oliver has no initial velocity so initial velocity1 is gone. The rock's finals velocity will be zero, so final velocity2 is gone.
You're left with:
m1+m2*initial velocity2=m1*final velocity1+m2
You should get his recoil velocity from that. If you don't then I'm wrong..and it wouldn't be the first time lol.
(59.1)+(.558)(19.8)=(59.1)*final velocity2+.558
1. What is recoil velocity?
Recoil velocity is the velocity at which a body moves in the opposite direction after a force is applied to it.
2. How is recoil velocity calculated?
Recoil velocity can be calculated using the equation v = m * u / M, where v is the recoil velocity, m is the mass of the object being propelled, u is the initial velocity of the object, and M is the mass of the object causing the recoil.
3. What factors affect recoil velocity?
The factors that affect recoil velocity include the mass and initial velocity of the object being propelled, as well as the mass of the object causing the recoil and any external forces acting on the system.
4. Can recoil velocity be negative?
Yes, recoil velocity can be negative if the object being propelled moves in the opposite direction of the force applied. This is often seen in scenarios where the object is being propelled downwards due to gravity.
5. How is recoil velocity used in real life?
Recoil velocity is commonly used in fields such as physics, engineering, and ballistics to calculate the motion of objects after a force is applied to them. It is also used in applications such as firearms, where understanding recoil velocity is important for accuracy and safety.
