Finding Supremum and Maximum
  • Thread starter hammonjj
hammonjj
33
For each subset of ℝ, give its supremum and maximum, if they exist. Otherwise, write none.
d) (0,4)
For part d, if the problem were [0,4], both the supremum and maximum would be 4, since the interval includes the end points, but I'm not sure about when it doesn't. It seems to me that the supremum would still be 4, as that qualifies as a least upper bound because 4 is in the neighborhood of the set, but is the maximum also 4? I don't think it would be since the interval does not include end points, but I'm confused!
Thanks!
Answers and Replies
LCKurtz
Insights Author
774
d) (0,4)
Thanks!
You aren't too confused. You are correct that the max is not 4. Does the max even exist?
hammonjj
33
I think it does, but I don't know what to call it. Since my interval is a subset of the real numbers, there's some x=4-ε, where x is the maximum and ε is some tiny interval that, when subtracted from 4, gives you the maximum of the set.
Am I making this too complicated? Does the max have to be some integer?
HallsofIvy
43,021
971
No, you are not making it too complicated, nor does the maximum have to be an integer. However, what you are saying, "there's some x=4-ε, where x is the maximum and ε is some tiny interval that, when subtracted from 4, gives you the maximum of the set" is wrong. The maximum of a set is, by definition the largest number in that set. If the set were "[0, 4]" or "(0, 4]" then the maximum would be 4. But (0, 4) is the set of all numbers larger than 0 and less than 4. If "x" is in that set, what could you say about (x+ 4)/2?
hammonjj
33
Since x is in the interval (0,4), that is x is less than 4, (x+4)/2 is in that interval.
LCKurtz
Insights Author
774
Even better, it is between x and 4. Hall's point is that any number x you might use for the maximum has to be in the interval so it is less than 4. Yet (x+4)/2 is in the interval and greater than x. So...?
Suggested for: Finding Supremum and Maximum
  • Last Post
