Finding Tangents Interesting
  1. Feb 26, 2008 #1
    Finding Tangents... Interesting !!!
    Hello,
    I have an interesting problem for you.
    I have a surface & an external point which is outside the surface.
    I need to find the equation of all the tangents on this surface which pass through the external point.
    Regards,
    AtulSharma
  3. Feb 27, 2008 #2
    Are you just trying to test us, or you really need an answer to this question?
  4. Feb 27, 2008 #3
    I myself need an answer to the problem.
  5. Feb 27, 2008 #4
    well, i am not sure whether my reasoning will be fine, because you have this surface, so if it were a curve it would most likely go like this.
    You first find the derivative of that function, most likely you will have to differentiate it implicitly, so this way you will manage to find the slope of the tangent line at any point on that surface, curve. So now you have this external point call it [tex](x_1,y_1)[/tex], so now the slope of the tangent will be
    [tex]\frac{y-y_1}{x-x_1}=m[/tex], but now you also have the slope of the tangent line at any point dy/dx so
    [tex]\frac{dy}{dx}=\frac{y-y_1}{x-x_1}[/tex], so you will manage to find a relation between [tex]x, and \ y[/tex] but you also have one relation given by the eq of the curve, so i think now you have to look for a solution, when this line only touches that curve. I am not sure whether my reasoning is okay, but wait for other replies as well!
  6. Feb 27, 2008 #5
    Well, I think its a good way to try. Let's see other replies also.
    Thanks for this solution.
  7. Feb 27, 2008 #6
    rcgldr
    Is this a 2D or 3D problem. If it's a 3D problem, are you looking for all the tangent planes that include the outside point, or only tangent lines that go through the point (in this case you end up with a cone)? If it's a 2D problem then you just end up with 2 lines. This is assuming the surface isn't complex, such as one that has both concave and covex components.
  8. Feb 27, 2008 #7
    This is a 3D problem. I need to find some (not all) of the tangents passing through the external point.
Loading...
