Finding Tank Volume
  • Thread starter Matt766
A tank for scuba diving is designed to contain 50 standard cubic feet of air when filled to a pressure of 3,000 pounds per square inch (gage) at an ambient temperature of 80 F. Calculate the interior volume of the tank. A standard cubic foot occupies one cubic foot at T=15 C and 101.3 kPa.
PV=nRT
I used PV/RT = PV/RT . I made sure all the units were correct but the volume I get is way too large.
Answers and Replies
NascentOxygen
Staff Emeritus
1,073
Hi Matt766. http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif [Broken]
Please show your arithmatic so readers can look for mistakes.
Sure. The underline is for division, and the temperatures go on the left and right of the equal sign respectively. Is there an equation editor or something?
(V * 3,000 lb/in^2) = (14.7 lb/in^2)*(86,414.7 in^3
(539.7 deg R) (518.7 deg R)​
V= 441.4 in^3. This seems weird to me because its such a small volume for a tank.
NascentOxygen
Staff Emeritus
1,073
Is Rankine going to work there?
Yes, looks like it can.
SteamKing
Staff Emeritus
12,798
1,670
One point here: the pressure in the tank is supposed to be 3000 psi gage. The ideal gas equation uses absolute pressure and absolute temperature.
Second point: where did 86,414.7 in.3 come from? After all, 1 foot = 12 inches, so 1 ft.3 = ??? in.3
NascentOxygen
Staff Emeritus
1,073
Didn't convert the right pressure to gage pressure, otherwise I can't see anything amiss. Yes, SK, should go with absolute temps though I see using R doesn't change the result here.
I made the tank pressure into an absolute pressure and corrected the volume for the cubic feet. For some reason I added 14.7 to the volume? Thanks haha
(V)*(3,014.7 lb/in^2)
= (86,400 in^3)*(14.7 lb/in^2)
V=438.4 in^3.
NascentOxygen
Staff Emeritus
1,073
From Wikipedia:
An especially common cylinder available at tropical dive resorts is an "aluminium-80" which is an aluminium cylinder with an internal volume of 0.39 cubic feet (11 L) rated to hold about 80 cubic feet (2,300 L) of atmospheric pressure gas at its rated pressure of 3,000 psi (210 bar).
4,996
V=438.4 in^3.
In this problem, considering how high the pressure is, we should also have used the compressibility z factor. The pressure is 200 atm., which corresponds to a reduced pressure on the order of about 6. In any event, giving the volume to 4 significant figures is not justified.
Chet
Related Threads on Finding Tank Volume
  • Last Post
  • Last Post
18K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
