Finding Tensile Force in Pulley Problem
In summary: Ft=-(M1a1+µM1a1)/M3,=-(M2a2+µM2a2)/M3, Which is what I was looking for.In summary, if you don't know the values for the coefficients of friction, you can't solve this equation.
Ryino
See Picture, The problem gives three boxes(M1, M2, and M3) and a few pulleys, no value for the coefficient of friction is given. None of the masses are known, and we are told to assume M1 and M3 are sliding. The objective is to find Ft
(if you can't see that well enough i made this)
F=ma
Ff=µma
First I started of by drawing free body diagrams for all of the boxes, Using these(and assuming M1 and M2 are sliding towards the middle) I came up with
M1:
FNET=Ft-Ff
M1a=Ft-µM1a
Ft=M1a+µM1a
M2 Would then have the same equations except M1 would be M2 because it also has
FNET=Ft-Ff
(I feel like that might be wrong but I'm not sure)
I'm not sure about the signs on all of those either.
Then I have for M3
FNET=Fg-Ft
At this point I'm not sure what to do, (the lack of values is killing me) I would think putting Ft from the M1 equation into the Ft equation would be a good start, but then everything except mass would cancel wouldn't it? So that doesn't seem right. I feel like I'm going in the right direction and I need to use these equations simultaneously some how but I'm not sure what to do for the next step as I don't see how this is going to get me Ft.
Also I'm starting to think M2 Net force is different
FNET=Ff-Ft (Since the ropes would be moving in opposite directions) and that would also change the equation for M2 to
M2a=µM2a-Ft
Ft=µM2a+M2a
But even if that's right, what would i do with it...?
Any help is appreciated, I'm currently stumped. :confused:
M1:
FNET=Ft-Ff
M1a=Ft-µM1a
Ft=M1a+µM1a
OK, but be careful to distinguish the accelerations of each mass--they aren't the same. Call this acceleration a1.
FNET=Ft-Ff
OK. Use a2.
Then I have for M3
FNET=Fg-Ft
Consider M3 and the pulley as a single object and apply Newton's 2nd law as before. (Careful with the tension force here.)
Key point: How does the acceleration of M3 relate to a1 and a2? Figure that out.
Hint: Set up these equations correctly and you'll have 3 equations and 3 unknowns. (Treat the masses and μ as knowns.)
(You're on the right track.)
If they are both treated as the same object then it would have two tensile forces on it correct?
Giving you FNET=M3a3-Ft1-Ft2
and a3=g=9.81m/s^2
Both of the tensile forces will be equal I assume so,
M3a=M3g-(2Ft)
Right?
Right.
and a3=g=9.81m/s^2
Well, I wouldn't use a3 to represent g; a3 is the acceleration of M3.
M3a=M3g-(2Ft)
Right?
Right.
Ryino said:
Also I'm not really sure how to go about this part of it, wouldn't it all be equal?
Play around with it, or figure it out by considering that the length of the rope doesn't change. Example: If M1 moves 1 m to the right and M2 moves 1 m to the left, how far does M3 move down?
I Solved for a3 in the net force equation for M3 and got
a3=9.81-(Ft1-Ft2)/M3
then I substituted the values i got for tension for the first and second box earlier and came up with
a3=9.81m/s^2 - ((M1a1+µM1a1)/M3)-((M2a2+µM2a2)/M3)
assuming i did my algebra right...
Is that what you meant by relating all three accelerations?Im looking at what i said and it makes me think, If a3 = 9.81-2Ft/M3
M1=M2 and a1=a2.
Although what you said earlier to label the accelerations different makes it seem like they shouldn't be equal.Edit:::
I Think this whole post is going in the wrong direction, read below post
Okay, so... If the Left box moves 1 meter right, and the Right box moves 1 meter left, The middle box moves down 1 meter So, (a1+a2)/2=a3
Ryino said:
So, (a1+a2)/2=a3
Exactly! This is the constraint equation relating the motion of the three masses. Now you should have all you need to solve for the tension.
(It's worth your time to learn how to derive this a bit more rigorously from the fact that the string length is fixed.)
If you solve for a1 in the first equation and a2 in the second equation
Plug the results into (a1+a2)=a3 and then substitute that into the the equation for M3
Using that solve for Ft
And you end up getting
Ft=[2m1m2m3(1+u)] / [m3(m1+m2) + 4m1m2]
I think i did that right but my teacher said that i will have M1 M2 M3 g and u. when I solve for Ft. My equation is missing the g.
What could i be doing wrong
OK, except that a3 = (a1 + a2)/2
That cannot be correct since the units don't match. The right hand side has units of mass, not force. (And yes, you should have a g in your answer.)
To find out where you went wrong, show the equations that you used.
Okay, for some reason i accidently substituted g for a1 and a2 on the right of the first two equations, I am reworking it now with the correct variables there, and i also see one other mistake...
This time through I am using the equations
M1a1=Ft-µM1a1 (1st equation)
M2a2=Ft-µM2a2 (2nd equation)
M3a3=Fg-Ft or M3a3=M3g-Ft (3rd equation)
a3 = (a1 + a2)/2 (4th equation) that's what I meant last time I just forgot to write the divided by 2 as I was typing it fast sorry
Ill edit this post when i get an answer with these equations
Careful: The tension pulls up on M3 twice.
Right. that's what i have written down, forgot that two when i typed it in. Other than that do all the equations look good? I'm still working on the algebra to solve it for Ft.
Yep; looks good.
I feel like I am really bad at algebra right now, so far i have
1/2m1(1+u)+1/2m2(1+u)=g/Ft-2/m3
Everything i do to this makes it feel like I am going backwards, if i multiply by ones on the right side to get a common denominator it takes that straight back to m3g-2Ft
Any suggestions on the next step? I'm still trying :cry:
Not sure how you ended up with Ft in the denominator.
Why don't you follow the same approach you described in post #8?
i had Ft/2m1(1+u) + Ft/2m2(1+u)=g-2Ft/m3 and i tried dividing by Ft
thats how it got on the bottom
With that i continued to 1/M1+1/M2=2g(1+u)/Ft - 4(1+u)/M3
I can multiply by Ft here to get it back on top on both the fractions on the left and the last fraction
And originally i solved for a1, a2, and substituting that into (a1+a2)/2=a3 and then substituted a3 into m3a3=m3g-2Ft
Thats where i started trying to get Ft
Since you want to solve for Ft, don't divide by it. Instead, start by collecting all terms with Ft on the left side of the equation. Then just factor out the Ft and simplify the result.
I think i got it Ft=2gm1m2m3(1+u)/(m2m3-m1m3+4m1m2(1+u))Is that correct? god i hope so
Edit:: I think i can pull out an M3 from the denominator and make it m3(m2-m1)+4m1m2(1+u)
You are very close but I think you made an error somewhere. (As a sanity check, you might want to consider the special case where all masses are equal and there's no friction. In that case the tension will be mg/3.)
Im trying to set all the masses equal and set my u to 0, and i can't find out where i messed up.
I substituted like that at the point where i got my last equation and it came to 2gm/5.
Can you see anything I'm doing wrong?from this point i would get the Ft on the left and factor/solve
Edit:: Wow I feel stupid it does work out to gm/3... For some reason i thought 4+1+1 was equal to 5 >.<. I'm working it out again
Ryino said:
I think i got it
Okay, i went back through it and, somehow i turned a positive into a negative in the middle of all my algebra for no reason. So now i have the same thing except
Ft=2gm1m2m3(1+u)/(m2m3+m1m3+4m1m2(1+u))
That's almost what I get. How did you get the (1+μ) in the denominator?
Unfortunately, I missed a few errors (typos, I presume) in your earlier equations:
The friction force terms should be μMg, not μMa.
(Algebra's a pain in the butt, ain't it? :wink:)
Darn, I thought I was going to be the first to catch that one :approve:
Unfortunately I used, μMa meaning I probably got it wrong. I turned it in today so i don't have any of the work with me. When I get it back (Wednesday maybe?) I'll go back over and finish out the problem the right way.
Hopefully I'll get partial extra credit for what I had. :smile:
1. What is a pulley?
A pulley is a simple machine that consists of a wheel with a groove around its circumference and a rope or cable that passes over the groove. It is used to change the direction or magnitude of a force, making it easier to lift heavy objects.
2. How do you find the tensile force in a pulley problem?
To find the tensile force in a pulley problem, you need to consider the weight of the object being lifted, the number of pulleys involved, and the direction of the applied force. You can use equations of motion and the principles of equilibrium to solve for the tensile force.
3. What factors affect the tensile force in a pulley system?
The factors that affect the tensile force in a pulley system include the weight of the object, the number of pulleys, the angle of the rope or cable, and the friction between the pulley and the rope. These factors can influence the magnitude and direction of the applied force.
4. What is the difference between the ideal and actual mechanical advantage of a pulley system?
The ideal mechanical advantage of a pulley system is the ratio of the output force (tensile force) to the input force (applied force). This assumes that there is no friction in the system. The actual mechanical advantage takes into account the effects of friction, which can reduce the efficiency of the pulley system.
5. How can you increase the tensile force in a pulley system?
To increase the tensile force in a pulley system, you can add more pulleys or increase the angle of the rope or cable. This allows the force to be distributed among multiple ropes, reducing the amount of force required to lift a heavy object. Additionally, reducing friction between the pulleys and the rope can also increase the tensile force.
11K
