Finding Tension of String
  1. Jan 12, 2006 #1
    http://img6.imageshack.us/img6/8772/leverrodtension3db.th.png [Broken]
    How do I find the tension of the string? (The image is from a hw problem)
    I want to know how to approach it. (hence, I left the numbers out)
    <edit>
    Here's the info they give in hopes of more response:
    Consider a lever rod of length L = 7.34 m,
    weight W = 69 N and uniform density. As
    shown on the picture below, the lever rod is
    pivoted on one end and is supported by a
    cable attached at a point b = 2.15 m from the other end.
    The lever rod is in equilibrium at angle beta =
    55 degrees from the vertical wall. The cable makes
    angle alpha = 70 degrees with the rod.
    What is the tension of the supporting cable? Answer in units of N.
    </edit>
    All the variables in the picture are given. Now in terms of the variables, how do I solve it??
    I think this is a torque and moment of inertia problem. But what equations will be used?
    I came up with the following by comparing it was a somewhat similar problem. However, the "b" variable is throwing me off as to how that is utilized.
    Help much appreciated. Thanks.
    Is the following even close to helping finding T?
    TL sin(beta) - Fg(L/2)sin(alpha) = O
  3. Jan 12, 2006 #2
    I would begin by summing the moments about the hinge
  4. Jan 12, 2006 #3
    Hootenanny
    Staff Emeritus
    b is simply there to give you the distance of the string from the pivot (d=L-b) it is at this point that a moment equal but oppposite to the moment caused by the weight of the bar.
  5. Jan 12, 2006 #4
    I've added the actual problem. I'm in need of desperate help since my exam is tomorrow and I want to know how to do this problem -- although it probably won't be on it (I hope).
    Help is much appreciated.:approve:
  6. Jan 12, 2006 #5
    Maybe T(L-b) sin(beta) - Fg(L/2)sin(alpha) = O
  7. Jan 12, 2006 #6
    yeah that looks right
  8. Jan 12, 2006 #7
    Thanks for the confirmation. I worked it out and the answer came out correct. (42.5330474 or 42.53 N)
