Finding tension? please help
My teacher is a dumbass and a horrible teacher. I swear he never taught us how to find tension and the "textbook" gives us long stories about little Billy and Bobby but never explains how to DO the problems. I need help for this question. Please explain if you can
A street lamp weighs 150N. Its supported by two wires that form an angle of 120 degrees with each other. The tension in the wires are equal.
a) what is the tension in each wire supporting the street lamp?
b) If the angle between the wires is reduced to 90 degrees, what is the tension in each wire?
2. Formulas Needed
no clue. sorry
3. Attempts
I don't know any of this so I couldn't even attempt to do it. I don't know where to even start
Answers and Replies
rock.freak667
6,230
31
Draw the free body diagram with all the forces acting. Then split then tensions in the wires into x and y components. Then use the fact that for equilibrium, the sum of the forces in a specified direction is zero.
LowlyPion
3,090
Welcome to PF.
Maybe you shouldn't be so hard on your teacher? At least the teacher likely knows how to figure the problem?
But as to equations this is a matter of resolving the force vectors from the information given. Drawing a diagram should be helpful.
You know what the vertical components of the tension must be in the two lines, hence you should be able to figure the Tension itself.
this doesnt help at all.
'kay, i figured it out on my own already. bye :)
LowlyPion
3,090
That's great. The system works and you learned how to solve the problem.
If someone had told you the answer you might have difficulty come exam time.
Related Threads on Finding tension? please help
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
