Homework Help: Finding the capacitance
  1. Feb 16, 2010 #1
    A science-fair radio uses a homemade capacitor made of two 45 45 sheets of aluminum foil separated by a 0.30-mm-thick sheet of paper. Assume dielectric constant of paper is 3.0.
    What is its capacitance?
    2. Relevant equations
    C=k e0 A / d
    3. The attempt at a solution
    I'm not sure if this is the wrong formula or if I am supposed to double .45m since there are two plates. Anyways, I came up with this...
    (3.0) * (8.85*e-12) * (.45) / .0003
    But the answer I came up with is wrong. Can anyone steer me in the right direction?
  3. Feb 16, 2010 #2
    you need the area of the plate in the equation, not the length of the side. 0.45m is the lenght of the side of the pieces of aluminium foil
  4. Feb 16, 2010 #3
    boom, what willem said. and next time include units on the 45, because that number means nothing to me
  5. Feb 16, 2010 #4
    and next time, if you have the answer in front of you and its a simple calculation such as this. divide your answer by the right answer, or vice versa, and you can figure out the factor that you are off by. and that can be very helpful
  6. Feb 16, 2010 #5
    oh im sorry, i wrote what i did down wrong. I did do by area -- 45cmx45cm=2025 and that is 20.25 meters. So i multiplied (3.0) * (8.85*e-12) * (20.25m) / .0003 and the answer I got was 1.79*e-6. I know I am messing up a simple calculation somewhere!!
  7. Feb 16, 2010 #6
    UNITS! If you are working in SI, then your area needs to be in m2:
    45cm x 45cm is equivalent to 0.45m x 0.45m = 0.2025m2
    Now try with that.
