Finding the components of stress in bone cement
In summary, the conversation discusses the calculation of strains and stresses in a given figure. Part A involves finding the values of the stresses, while part B involves calculating the strains using given equations. Part C discusses the correctness of the equations used in part B and clarifies that the shear components of the stress tensor are zero in this case.
nerdeagle24
The volume shown below is a piece of bone cement, a project you have been working on
for 2 years. It is finally ready for mechanical analysis. To mimic one possible in vivo
condition, the material was loaded with the stresses shown. You must perform the
following analysis in order to prepare for the next round of tests.
a) What are the values of σxx, σxy, σyx, and σyy in the 2D state of stress?
b) Given values of E = 19 GPa and ν = 0.36, which are reasonable values for bone, find the
values of strain for the figure below and assume that the material is linear, elastic,
homogeneous, and isotropic.
c) In the next phase of testing the loading conditions are getting more complex. For that test,
you will be adding an additional load 28o above the horizontal. Before starting you must fully
understand the effect of the current loading conditions at that angle. For the conditions
shown, find the values of σxx’, σxy’, and σyy’ for CCW rotation about the z axis of θ = 28°.
Note, equal stress force on arrows across from each other.
Strain x = (1/E)(sigma +v sigma y)
Shear Stress = G*shear strains
I am really stuck on part a.
For part b:
strain x = (1/19*10^9)(137000+.36*95000)
strain y =(1/19*10^9)(-95000-.36*137000)
Is this right?
For part c:
sigma xx'=(sigma x+sigma y)/2+(sigma x -sigma y)cos(2*28)/2+sigma xy sin(s*28)
sigma yy'=(sigma x+sigma y)/2-(sigma x -sigma y)cos(2*28)/2-sigma xy sin(2*28)
sigma xy'=-(sigma x-sigma y)sin(2*28)/2+sigma xy cos(2*28)
Are these equations correct?
I also think sigma xy = sigma yx
Before getting to part c, your equation for the strains in part b both have sign errors in them.
I got to start with part A. I will look at the signs as well for part b. How do I even start part A?
The values of the stresses are shown in the figure. ##\sigma_{xx}=137 kPa##, ##\sigma_{yy}=-95 kPa##
Yes. But what about sigma xy and sigma yx? I know they are equal but how do you calculate them?
There's nothing to calculate. There are no shear (tangential) loads applied in the figure. Those components of the stress tensor are zero.
1. What are the main components of bone cement?
The main components of bone cement are a powder phase, typically made of polymethylmethacrylate (PMMA) or a similar material, and a liquid phase, typically made of methylmethacrylate (MMA) or a similar material. Other additives such as antibiotics, radiopacifiers, and accelerators may also be included.
2. How do the components of bone cement interact with each other?
When the powder and liquid phases are mixed, a chemical reaction occurs that results in the formation of a solid polymer network. This network is responsible for the strength and stability of the bone cement, and the additives can affect its properties in various ways.
3. What factors can affect the stress within bone cement?
The stress within bone cement can be affected by several factors, such as the composition and proportions of the components, the mixing technique, the curing time, and the presence of any voids or defects within the cement. Additionally, external factors such as the load applied to the cement and the surrounding bone can also impact the stress.
4. How can the components of bone cement be optimized to reduce stress?
To reduce stress within bone cement, the components can be optimized by carefully selecting and controlling the composition and proportions of the powder and liquid phases, as well as any additives. The mixing technique and curing process can also be optimized to ensure a homogeneous and well-bonded cement. Additionally, minimizing any voids or defects within the cement can help reduce stress.
5. What methods can be used to measure the stress within bone cement?
The stress within bone cement can be measured using various techniques, such as strain gauges, digital image correlation, and finite element analysis. These methods can provide information about the distribution and magnitude of stress within the cement, which can help in the optimization and evaluation of the cement's performance.
