Finding the fianl Velocity
  • Thread starter wermichiel
wermichiel
The model is a car with weights dropping from certain height and propels the car forwards. (Some GPE converted to KE knowledge involved.) And the question is to find a theoretic maximum velocity (final velocity) as the mass of car/weight and the height of weights are constant. All the frictions are not taking in consideration. We know the distance(s) and the time (t), also the M (mass of weights) and the H(height of weights).
What I did is to measure the running time of car and the distance the car traveled within this time. Therefore, the work has done is completely equal to the kinetic energy. W=KE=GPE=mgh. (Due to the formula W=Fd, the force can be calculated. Then F=ma, acceleration of car has worked out. Finally the V, by Vt=V0+at, is calculated.
My question is that is this the easiest way to solve it? Is there any other method that can work without thinking so many procedures?
Answers and Replies
tiny-tim
25,836
255
Welcome to PF!
Hi wermichiel! Welcome to PF!
… (Due to the formula W=Fd, the force can be calculated. Then F=ma, acceleration of car has worked out. Finally the V, by Vt=V0+at, is calculated.
Yes!
Your formula W = Fd (for the work done) doesn't really work in this case (what is d?).
As you say, KE = GPE= mgh,
so just use KE = 1/2 mv2. :wink:
wermichiel
thanks for answering.
but what i trying to do is comparing the actual and theoretical final velocity
as I cannot measure the actual final velocity in the experiment, only average velocity can be worked out by Va= S/t =.=
however the KE=1/2mv^2 is dealing with the final velocity
this is where I am struggling
W=fd, f=force d=distance, w= work
wermichiel
a = 2(s - ut)/t2
ah!! a formula is applied to this condition!!!
calculating the A by this way can avoid the calculation of work
then use V=U+at , there is the V!
Suggested for: Finding the fianl Velocity
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
