Calculating the Flash Frequency in a Neon Lamp Circuit
In summary, the blinking light circuit uses a neon lamp and a capacitor to create a simple RC circuit. When the voltage across the capacitor reaches 75 V, the neon will ionize very quickly and the neon lamp will become a very good conductor, and will immediately discharge the capacitor.
Myr73
120
A simple type of blinking light circuit can be constructed using a neon lamp. The
circuit shown here has a 4.0 μF capacitor in parallel with a neon lamp. When the
voltage is low in the RC portion of the circuit, the lamp does not conduct
electricity. Therefore, it is
effectively not there from an
electrical point of view. The RC
circuit will then charge from the
110 V power supply. However,
when the voltage across the
good conductor, and will immediately discharge the capacitor. The energy stored
in the capacitor will be given off as a flash of orange light, making this a useful
circuit. After the flash, the charging process will start once more since the
voltage will again be low.
a. Determine the flash frequency with the resistance value shown.
b. Make a sketch of the voltage across the capacitor versus time in such a
circuit, showing several periods.
C=4X10^-6 ε=110V Vc=75V R= 2.5 X 10-4
t=1/f T=RC Vc=ε(1-e^t/RC)
So for a) I have T=RC= (2.5X10^-4)(4X10^-6)= 0.1s <-- time constant for the circuit
Vc=ε(1-3^t/RC)
In (1-{Vc/ε))=-t/RC
t= -In (1-V{c/ε})(RC)
What I don't understand is how to calculate that
Lots of jumble here.
R is not 2.5e-4. It's 2.5e4.
Vc is not what you have, which is Vc=ε(1-3^t/RC). What's with the "3"? And is the sign of the exponent correct?
Miraculously, your expression for t is correct if you straighten out your parentheses and write ln instead of In.
FIx that up and go from there.
wow, you really are a rude man-lol
yes i see I got a couple typos there-
So for a) I have T=RC= (2.5X10^4)(4X10^-6)= 0.1s <-- time constant for the circuit
Vc=ε(1-e^t/RC)
ln (1-{Vc/ε))=-t/RC
t= -In (1-{Vc/ε})(RC)
I calls 'em like I sees 'em - don't take it personally! :smile:
Vc=ε(1-e^t/RC)
ln (1-{Vc/ε))=-t/RC
What is it you don't understand?
You know Vc, ε, and RC, so why can't you put in the numbers and solve for T = -(RC)ln(1-{Vc/ε})? Got a hand calculator handy?
umm I don't know what to do with the " ln ".
The ln function is available in the standard Windows calculator (or equivalent if you use a different OS), just set it to "Advanced mode" (alt-2).
Oh ok I found it, but if I don't have a calculator, how is that calculated?
Google it Write "natural logarithm of N" where N is your number.
In my day we used slide rules. Consider yourself very lucky!
1. What is the flash frequency and why is it important?
The flash frequency is the number of flashes produced by a light source per unit of time, usually measured in Hertz (Hz). It is important because it can provide information about the behavior and characteristics of the light source, such as its intensity and stability.
2. How do you measure the flash frequency?
The flash frequency can be measured using specialized equipment such as a photodiode or photometer, which can detect and count the number of flashes in a given time interval. Alternatively, it can also be estimated by recording a video of the light source and counting the number of flashes in a given time frame.
3. What factors can affect the flash frequency of a light source?
The flash frequency of a light source can be affected by various factors such as the power supply, the type of light source, the temperature, and the presence of any external factors that may interfere with the light emission. Additionally, changes in these factors can also cause variations in the flash frequency.
4. How can the flash frequency be used in scientific research?
The flash frequency can be used in scientific research for a variety of purposes. It can provide information about the properties and behavior of the light source, which can aid in the development and improvement of lighting technology. It can also be used in studies on animal behavior, as many species are sensitive to certain flash frequencies and can be attracted or repelled by them.
5. Can the flash frequency be altered or controlled?
Yes, the flash frequency can be altered or controlled by adjusting various parameters such as the power supply, the intensity of the light source, or the type of light emitting material. Additionally, specialized equipment such as strobe lights can also be used to produce specific flash frequencies for various applications.
