Calculating the Fourier Transform of a Digital Signal
In summary: I obtained 4sin2W + 2sinW = 2(2sinw + sinw) is this correct?/That's not quite correct.The trig identity is\sin x = \frac{1}{2i}(e^{ix} - e^{-ix})Now multiply both sides by 2i to get the formula you need. In particular, notice that your answer will be imaginary, not real.Oh sorry I think
  • #36
Ive just noticed I may have made an error. For the Fourier transform mentioned in post 18.
I concluded that:
8i sin2x + 4i sinx
could be written as:
4i (sin2x+sinx)
However I have missed a 2 out from sin2x.
So should it be:
4i (2sin2x + sinx)
marcusl or jbunni does this look correct to u?
  • #37
I concluded that:
8i sin2x + 4i sinx
4i (sin2x+sinx)
So should it be:
4i (2sin2x + sinx)
It looks right to me. I hadn't noticed the earlier error you pointed out.
  • #38
Thanks Jbunnnii I only just noticed it myself. For the first Fourier transform i sketched the magnitude of the function and it oscillates between 9 and 6.708. From -3pi to 3pi. This seem correct to u??
  • #39
Also would the magnitude of:
4i (2sin2x + sinx)
be
SQRT-16 .((2sin2x)^2 + (sinx)^2)
which would give me imaginary numbers so cannot be plotted.
  • #40
4i (2sin2x + sinx)
be
No, that's not right.
What is the magnitude of 4i? It's 4, not -4.
  • #41
Ah i see so the magnitude would be:
4.SQRT((2sin2x)^2 + (sinx)^2)
  • #42
No, you left out a term.
The magnitude is
[tex]4 \sqrt{(2 \sin 2x + \sin x)^2}[/tex]
When you expand the square, you get three terms, not two.
Or, you can simply express it as
[tex]4 |2 \sin 2x + \sin x|[/tex]
which is probably easier to work with if all you want to do is plot it.
  • #43
Ok I thought magnitude was fo example:
SQRT((a)^2 +(b)^2) not SQRT (a+b)^2
SO to plot magnitude i must expand the brackets to give me three terms. Could u expand the brackets I am little confused.
  • #44
The first form is not true in general, but only if a and b are the lengths of two perpendicular vectors and you want the magnitude of the sum of the vectors. (Think Pythagorean theorem.) For example, if z was a complex number, with real component a and imaginary component b, then
[tex]|z| = \sqrt{|z|^2} = \sqrt{|a + bi|^2} = \sqrt{(a + bi)(a - bi)} = \sqrt{a^2 + abi - abi + b^2} = \sqrt{a^2 + b^2}[/tex]
Notice that the middle two terms, [itex]abi[/itex] and [itex]-abi[/itex], canceled each other. This happens precisely because [itex]a[/itex] and [itex]bi[/itex] are perpendicular to each other.
But you have a different situation. You have a real number,
[tex]2 \sin 2x + \sin x[/tex],
and you want its magnitude (absolute value).
In general, if [itex]r[/itex] is a real number, then its absolute value is
[tex]|r| = \sqrt{|r|^2} = \sqrt{r^2}[/tex]
So in your case
[tex]|2 \sin 2x + \sin x| = \sqrt{(2 \sin 2x + \sin x)^2}[/tex]
Now expand the square:
[tex](2 \sin 2x + \sin x)^2 = 4\sin^2 2x + 4 \sin 2x \sin x + \sin^2 x[/tex]
The middle term is the one you are missing.
  • #45
Rite ok I understand now how to calculate magnitude. All I have to do now is sub values form -3pi t0 3pi in order to gain the plot required.
Should I adopt the same technique for:
[tex]
3\cdot|1 + 2\cos \omega + 2 \cos 2\omega |
[/tex]
  • #46
[tex]
[/tex]
Yes, although as I mentioned before, it might be easier if you use the equivalent form
[tex]3 \cdot \left| \frac{\sin(2.5 \omega)}{\sin(0.5 \omega)} \right|[/tex]
  • #47
Ye I will adopt ur equvalent form to plot with. With the magnitude obtained for the second Fourier transform where u expanded the square. Would it be easier to rewrite:
sin^(2) x using the chain rule to obtain 2sin(x)cos(x)
Just as I am using Excel to plot the magnitudes. And would that give:
4sin^(2) 2x = 8sin2xcos2x
