Homework Help: Finding the gain of a circuit
  1. Jul 7, 2011 #1
    I have started working on a summer assignment for my Fall semester EE course and was given a gain problem with an op amp (Problem shown below - EE P3.1). My professor also gave me, what he calls, 'Typical Homework Solutions.' I have based most of my work with the example problem he gave us(Attatchment EE P3.2), but have come to a dead end in my work...
    (Attatchment below - EE P3.1)
    Determine the transfer function of the circuit given.
    2. Relevant equations
    Vn(t) = Vp(t)
    Vp(t) = Vi(t)
    Vn(t) = Vp(t) = Vi(t)
    3. The attempt at a solution
    (Attatchment below - EE P3)
    0 = (G1 + C1s)Vi(t) + G2[Vi(t) - Vo(t)]
    The thing that doesn't seem right is (looking at EE P3) that if I were to bring the Vi(t) over to the right of the equation so it is Vo(t)/Vi(t), the gain would then be ((G1 + C1s)+G2)/(G2) and that just does not seem like the correct answer.... Any ideas/input as to if I'm just wrong in thinking that is not right?
  3. Jul 7, 2011 #2
    donpacino
    ok you want to do nodal analysis. in an ideal op-amp with high gain negative feedback the negative input is equel to the positive input. so the equation is.
    vi/(r1+1/c1)+(vi-vo)/(r2)=0
    note that i did not convert to s yet. you are supposed to convert to s first however i havnt done this problem yet
    when you convert to s i think all that happens is the 1/c1 becomes 1/(sc1)
    ps. guess who i am
  4. Jul 7, 2011 #3
    It is wrong to write the impedance of a capacitor 1/c1 and then "convert to s." It is not correct to write the impedance of a capacitor as 1/c1, generally.
  5. Jul 7, 2011 #4
    donpacino
    then how would you do it? don't criticize if you cant show me a better answer
  6. Jul 8, 2011 #5
    The first equation I would write would be in the s domain.
    something like:
    [itex]\frac{V_{i}}{R_{1} + \frac{1}{C_{1}s}} =\frac{V_{o} - V_{i}}{R_{2}} [/itex]
    where Vi and Vo are the Laplace transforms of vi(t) and vo(t), respectively.
    This is much like what you wrote, except without the incorrect "1/c1".
  7. Jul 8, 2011 #6
    Hahah hi Leo :tongue:
    I understand where you're coming from.. But when you do this I don't quite understand how you algebraically have an end result of [itex]\frac{V_{o}}{V_{i}}[/itex].. Any advice on this?
  8. Jul 8, 2011 #7
    gneill
    Staff: Mentor
    Cross multiply, expand each side and collect like terms (vo's and vi's)... the usual algebraic dance :smile:
  9. Jul 8, 2011 #8
    Haha wow I feel stupid for not seeing that.... :redface: I worked it out and found a gain shown in the attatchment below. Does this gain seem correct? I also "attempted" in putting it in the form the professor asked for.. and I think that went miserably wrong..
  10. Jul 8, 2011 #9
    gneill
    Staff: Mentor
    Your algebra is a bit "exotic" :smile:
    Try this:
    [tex] \frac{v_i}{R_1 + \frac{1}{s C_1}} = \frac{v_o - v_i}{R_2} [/tex]
    Cross multiplying:
    [tex] v_i R_2 = (v_o - v_i)\left(R_1 + \frac{1}{s C_1}\right) [/tex]
    Now separate the v terms and proceed.
  11. Jul 8, 2011 #10
    Haha I did do this, maybe I didn't show it very well. I did what you showed, then brought the vi over to produce the gain and cancel out a set of vi's, which = -1. I then took the 1 and added it to the left side of the equation. Does this make it more clear?
  12. Jul 8, 2011 #11
    gneill
    Staff: Mentor
    [tex] v_i (R_2 + R_1 + \frac{1}{s C_1}) = v_o \left(R_1 + \frac{1}{s C_1}\right) [/tex]
    [tex] \frac{v_o}{v_i} = \frac{(R_2 + R_1 + \frac{1}{s C_1})}{\left(R_1 + \frac{1}{s C_1}\right)} [/tex]
    [STRIKE]Now pull R1 + R2 out of the numerator, and R1 out of the denominator. Proceed.[/STRIKE]
    EDIT: Better idea: multiply numerator and denominator by sC1.
  13. Jul 8, 2011 #12
    Gotcha, it may be a silly question.. but by doing so would it not cancel out the sC1 in the numerator and denomenator?
  14. Jul 8, 2011 #13
    gneill
    Staff: Mentor
    Not quite, it has the effect of turning the 1/sC1 terms into 1's, and turning the resistance terms into s*R*C type terms... otherwise known as s/ω type terms...
  15. Jul 8, 2011 #14
    I did not realize that was the the actual term s/ω, which is what form the professor asks for the answer to be in. So s*R*C is equivilent to s/ω?
  16. Jul 8, 2011 #15
    gneill
    Staff: Mentor
    Yup. The units of R*C yield seconds. 1/seconds yields a frequency...
  17. Jul 11, 2011 #16
    From what you have said, I found a gain and found ωz & ωp (shown in attatchment), although what doesn't make sense to me is that there is no ALF.. my thoughts were that (where I circled and labeled 1) there were missing parentheses and the R2 should be ALF?? I could be wrong and just not understanding this problem at all
  18. Jul 11, 2011 #17
    gneill
    Staff: Mentor
    The frequency terms have form s/ω (the ω's themselves do not contain s), so you should have
    [itex] w_z = 1/((R_1 + R_2)*C_1) [/itex]
    [itex] w_p = 1/(R_1*C_1) [/itex]
    A low frequency gain of unity, [itex] A_{LF} = 1 [/itex], should be perfectly acceptable.
  19. Jul 11, 2011 #18
    Ok ok I now see what you mean and understand it a lot better. I needed to keep going and factor out the s from both the ωz & ωp, which then gives me an end result of ωz = [itex] 1/((R_1 + R_2)*C_1) [/itex] & ωp = [itex] 1/(R_1*C_1) [/itex], exactly what you got which is great!
    I understand how I got a low frequency of 1, I just don't really understand the purpose/information on the actual term low frequency gain.. If that makes sense
  20. Jul 11, 2011 #19
    gneill
    Staff: Mentor
    The low frequency gain tells you what the circuit gain will be when the input signal is of very low frequency (DC or approaching DC). So if, for example, the input signal happened to be a 1V DC value, the output would settle at 1V also.
  21. Jul 11, 2011 #20
    Ahh alright now I understand this better than before and understand the problem. Thank you for all of your help/input and explanations!! They are greatly appreciated and very helpful!
