Solve Modulus for (3-4i)^10/(2-i)^8
  • Thread starter hadroneater
  • Tags
    Modulus
In summary, the conversation discusses finding the modulus for a complex number expression and the attempt at solving it by converting the terms into their exponential forms and performing exponential operations. However, the argument values are not exact numbers, leading to confusion about the approach. The expert suggests that the modulus for 3-4i would simply be 5, correcting the confusion between modulus and conjugate.
hadroneater
59
Find the modulus for:
(3 - 4i)^10/(2 - i)^8
I tried putting the two terms in their exponential forms. Then do simple exponential operations and convert back to cartesian form to get the modulus.
3 - 4i = [itex]5e^{arctan(-4/3)}[/itex]
2 - i = [itex]\sqrt{5}e^{arctan(1/2)}[/itex]
However the arguments aren't going to be exact numbers. Is there another way to approach this question?
You left out an i on your exponents in polar form. But that's besides the point. Don't you think modulus of 3-4i would just be 5? Why or why not?
Right. I confused the definition of Modulus with Conjugate. Man, I feel stupid.
Thanks!
1. What is the modulus of (3-4i)^10/(2-i)^8?
The modulus of a complex number is its distance from the origin on the complex plane. In this case, the modulus of (3-4i)^10/(2-i)^8 can be calculated by taking the absolute value of the complex number. This can be done by finding the square root of the sum of the squares of the real and imaginary parts. The final answer will be a positive real number.
2. How do you simplify the expression (3-4i)^10/(2-i)^8?
To simplify this expression, we can use the properties of exponents and the quotient of powers rule. First, we can expand (3-4i)^10 and (2-i)^8 using the binomial theorem. Then, we can divide the two expressions by writing them with a common base and subtracting the exponents. Finally, we can simplify the resulting expression by combining like terms and simplifying any remaining complex numbers.
3. Can the modulus of a complex number be negative?
No, the modulus of a complex number is always a positive real number. This is because it represents the distance from the origin on the complex plane, which can never be negative.
4. How does the modulus of a complex number change when it is raised to a power?
When a complex number is raised to a power, its modulus is also raised to that power. This means that the distance from the origin on the complex plane will increase or decrease depending on the value of the exponent.
5. What is the significance of the modulus in complex number operations?
The modulus of a complex number is important in operations involving complex numbers because it helps us understand the magnitude or size of the number. It also allows us to find the distance between two complex numbers and to compare the sizes of different complex numbers. In addition, the modulus is used in polar form to represent complex numbers, making it a crucial concept in complex number operations.
  • Linear and Abstract Algebra
