What is the Method for Finding the nth Term of a Series Given Sn?
  • Thread starter remaan
  • Tags
    Term
In summary, the conversation discusses finding the formula for the nth term of a series when given the sum of the series, Sn. The conversation includes a discussion on the difference between Sn and S(n+1), the use of partial sums, and finding Sn by subtracting S(n-1). Ultimately, the conversation ends with the formula for an being 2^(-n) * ((n-1)*2^(-n) - n).
remaan
132
This type of questions seems to be easy, but a little confusing at the same time
If we are given the Sn of a series, and were asked to find an how to do that ?
the limit of series and Sn is the same
Maybe we should divide an and Sn ??
What's the difference between S_n and S_(n+1)?
I think that the only difference is one comes before the other, however they both have the same limits
Maybe you'd better define what S_n means. I thought I knew what you were talking about. But your answer isn't reassuring.
Sn is the partial sum of the nth term of a series .
No, it's the partial sum of the first n terms in the series. a1+a2+a3+...+an. What would 'partial sum of an nth term' mean?
Uha, and how to use to find an ?? When we know Sn as stated in the question ?
I'll ask you again. Using slightly different words. What's S_(n+1)-S_(n)?
I think that this is an right ?
SO do I have to find S(n+1) and subt. from S (n) ??
Is that what you mean ?
That was supposed to be a hint, not the answer. I would say S_(n+1)-S_(n)=a_(n+1). You'll have to change it a little to get a_(n). But, yes, that's what I mean.
mmm, ok what do you think of this
If the Sn = 3-n(2)^(-n )
I did what you suggested and I got that an = 2^(-n) ( n+2n+2)
Do you think that can be right ?
That's not what I get. How did you work that out?
an = Sn - S (n-1)
I found that Sn-1 = 3-(n-1)2^(-n+1)
Is that right, before I precede ?
Looks ok to me.
Ya, and that 's how I got the rest !
I think I am fine "with this one "
Thanks a lot Dick
Ok, you're welcome! But I still don't get 2^(-n) ( n+2n+2).
I got that by sub. Sn - S(n-1)
and then I took 2^(-n) as a common factor..
What do you think ?
I think it's wrong. If you'd show the rest of your work maybe we could figure out why.
Uha, sure :
here what I did :
Sn- S(n-1) = 3-n2(-n) - [ 3- n 2^(-n+1) - 2^ (-n+1) ]
3 we cancel and then we got what told you defore a while ,,
What do you think ?
The '3's cancel, sure. I'm left with (n-1)*2^(-n+1)-n*2^(-n). If I factor 2^(-n) out I've got 2^(-n)*((n-1)*2-n). Right? Be more careful with the signs.
Thank's Dick ... I ok now ..
What is the "nth term" in a sequence?
The "nth term" refers to the general term or formula that allows you to find any term in a sequence. It is often denoted as "an", where "n" represents the position of the term in the sequence.
How do you find the nth term in a sequence?
To find the nth term in a sequence, you need to first identify the pattern or rule that governs the sequence. Once you have identified the pattern, you can then use it to create a formula for the nth term. This formula can then be used to find any term in the sequence.
What is the difference between the nth term and the first term in a sequence?
The first term in a sequence is the initial value or starting point, whereas the nth term is a general term that allows you to find any term in the sequence. The first term is typically denoted as "a1", while the nth term is denoted as "an".
Can you find the nth term in a non-linear sequence?
Yes, you can find the nth term in a non-linear sequence as long as you are able to identify the underlying pattern or rule. However, the formula for the nth term may be more complex in non-linear sequences compared to linear sequences.
Why is finding the nth term in a sequence important?
Finding the nth term in a sequence is important because it allows you to easily find any term in the sequence without having to manually write out each term. It also helps you to understand and predict the behavior of the sequence, which can be useful in various mathematical and scientific applications.
