• Support PF! Buy your school textbooks, materials and every day products Here!
Finding the period
  • Thread starter zumi78878
The pendulum shown below right consists of a uniform disk with radius r = 20.0 cm and mass m = 1.2 kg attached to a uniform rod with length L = 40 cm and mass M = 0.8 kg. What is the period of the motion?
T = 2∏√(I/mgL)
I dont know what to plug into what.
Answers and Replies
Doc Al
Mentor
44,945
1,206
To start with, you need to calculate the rotational inertia (I) of the system about the axis of rotation. How would you do that?
Also, in your formula for T what does L represent? You'll have to find that as well.
T = 2∏√(I/mgL)
L represents the distance to the center of mass of the system?
L = [(1.2*(0.4+0.6)/2)+(0.8*(0.4/2)]/(1.2+0.8)
= 0.38m?
using parallel axis theorem:
I = 1/2MR2 + ML2
= (0.5)(1.2)(0.2)2 + 0.8(0.2+0.4)2
=0.312?
Doc Al
Mentor
44,945
1,206
T = 2∏√(I/mgL)
Right.
= 0.38m?
What's the distance from the center of the disk to the axis?
I = 1/2MR2 + ML2
=0.312?
Things are a bit mixed up here. Find the rotational inertia for each piece separately, then add them up. To find the I of the disk about the axis, you'll need the parallel axis theorem. What's the I of a thin rod about one end?
Right.
T = 2∏√(I/mgL)
= 0.38m?
the distance from the center of the disk to the pivot is 0.6m.
L = [(1.2*0.6)+(0.8*(0.4/2)]/(1.2+0.8)
= 0.44m?
I of disk = 1/2MR2 + ML2= 1/2(1.2)(0.2)2 + (1.2)(0.6)2= 0.456?
I of thin rod = 1/3ML2 = 1/3(0.8)(0.4)2= 0.0427?
I total = 0.4987?
I have an exam in 45 minutes so i really need to get this cleared up before that.
Doc Al
Mentor
44,945
1,206
= 0.44m?
I total = 0.4987?
Looks good.
Right.
Looks good.
wen i plug m into the formula, T = 2∏√(I/mgL)
do i use the mass of the entire system? so 1.2 + 0.8 = 2kg?
Doc Al
Mentor
44,945
1,206
Yes.
For more insight into the physical pendulum and how that equation comes about, review this: Physical Pendulum
Yes.
thanks so much for ur help! really appreicate it. glad there are people like you out there.
but last question, can you explain why it has a negative sign in
Torque = -mgLsinθ?
Doc Al
Mentor
44,945
1,206
Torque = -mgLsinθ?
Because the torque is in the direction of decreasing θ. (It's a restoring force, tending to bring the system back to the equilibrium point.)
Good luck on your exam!
Related Threads on Finding the period
  • Last Post
13K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
14K
  • Last Post
  • Last Post
  • Last Post
22K
  • Last Post
