Homework Help: Finding the stoping distance.
  1. Sep 22, 2008 #1
    Acceleration = -3m/s^2
    Meters per second = 11.18
    if i were to find the stopping distance what formula should i use?
    Vo + at = Vf
    d = Vo x t + 1/2 x at^2
    Vf^2 = Vo^2 + 2ad
  3. Sep 22, 2008 #2
    The 11.18, is it the Vf or Vi (or both?). Don't use a formula with t because you are not given a time. I would use the last one, Vf^2-Vi^2=2ad since you have ALL that information.
  4. Sep 22, 2008 #3
    the 11.18 is the vi. How can i do this problem can you show me step to step? i have like 10 of these and hope to see how to do this one first.
  5. Sep 22, 2008 #4
    mgb_phys
    Simple rule:
    What do you know = u, v and a (hint you know final velocity=0)
    What don't you know = t
    What are looking for = d
    which one gives you 'd' in terms of u,v,a ?
  6. Sep 22, 2008 #5
    using the 3rd formula i got..
    vf^2 = 125 + 2ad
    /2a both side
    vf^2 / 2a = d
    and then what else do i do?
    and is this right?
  7. Sep 22, 2008 #6
    mgb_phys
    You know about how to rearrange formulae?
    vf2=vi2 + 2ad
    2ad = vf2 - vi2 and since vf=0 ie stopped
    d = - vi2 /2a
    Hint, put the units in for each number and check they cancel to give metres
  8. Sep 22, 2008 #7
    nvm this is what i got....
    vf^2 = 2ad
    127/2a = d
    after that?
    127a/2a
    = 127 / 2
    = 63.5?
  9. Sep 22, 2008 #8
    how is vf 0 when it only tells me meters per second is 11.18 and acceleration -3m/s?
  10. Sep 22, 2008 #9
    cepheid
    Staff Emeritus
    Well, the *stopping* distance is the distance over which the object travels before *stopping*. If it is stopped, then its final velocity is ZERO. That's what it means to come to a stop...to no longer have any speed, in any direction.
    Edit: and just to complete the thought, vf is the symbol for final velocity in this problem.
  11. Sep 22, 2008 #10
    at the end i got d = -9 / 2a
    what do i do after this?
    -9a / 2a
    = -9 / 2
    d = -4.5
    is that right?
  12. Sep 22, 2008 #11
    cepheid
    Staff Emeritus
    I would check your algebra if I were you. The square of the velocity is NOT equal to 9.
  13. Sep 22, 2008 #12
    d = 125 / 2 * -3
    d = 125 / -6
    d = -20.83
    is this right?
  14. Sep 22, 2008 #13
    cepheid
    Staff Emeritus
    The numbers are right. The answer should not be negative because there are TWO negative signs, one on the top, and one on the bottom (the -3). So the two negative signs will cancel, if you did your algebra properly.
  15. Sep 22, 2008 #14
    mgb_phys
    Remember an answer in physics without units is WRONG.
    In addition the units check that you got the formula right.
  16. Sep 22, 2008 #15
    mgb_phys i got -20.83. is that right?
  17. Sep 22, 2008 #16
    because it's like this
    d= 11.18^2 / 2 * -3
    = 125 / -6
    = -20.83
    how can it not be negative?
  18. Sep 22, 2008 #17
    mgb_phys
    d = vf2 - vi2 /2a
    vi = 11.18 m/s
    vi = 0 m/s
    a = -3 m/s2
    d = 0 - 11.182 m2s-2 /(2*-3) m/s2 = 20.8 m
  19. Sep 22, 2008 #18
    cepheid
    Staff Emeritus
    Ummm...hello? Already answered this question!
  20. Sep 22, 2008 #19
    LowlyPion
    I think your original equation was wrong.
    Vf2 = Vo2 - 2*a*d
    The negative sign because your acceleration is negative (slowing)
    This then rearranges to Vo2 = 2*a*d
    No negative signs, and distance in the direction of the initial velocity.
