negation
- 818
Let A→ = 15i -40j and B→ = 31j + 18k. Find C→ such that A→+B→+C→=0
A + B = 15i - 9j + 18k
C = -15i + 9j -18k
Vector addition is a mathematical operation that involves combining two or more vectors to create a new vector. It is used to represent the combination of multiple forces acting on an object.
To solve for C→, you need to rearrange the equation to isolate C→ on one side. This can be done by subtracting A→ and B→ from both sides of the equation, resulting in C→=-A→-B→. This means that C→ is equal in magnitude and direction to the negative sum of A→ and B→.
If C→=0, this means that the three vectors A→, B→, and C→ are in equilibrium. This can also be interpreted as the object being at rest, as the net force acting on it is equal to zero.
No, in order to solve for C→, you need to have all three vectors (A→, B→, and C→) given. This is because the equation represents the vector sum of all three vectors, and without one of the vectors, you cannot accurately determine the magnitude and direction of C→.
Vector addition is used in various fields such as physics, engineering, and navigation. It is used to calculate the net force acting on an object, design structures that can withstand multiple forces, and determine the direction and speed of an object's movement.
