Homework Help: Finite Definition of Languages problem
  1. May 28, 2012 #1
    A palindrome over an alphabet Ʃ is a string in Ʃ* that is spelled the same forward and backward. The set of palindromes over Ʃ can be defined recursively as follows:
    i) Basis: λ and a, for all a that are elements of Ʃ, are palindromes.
    ii) Recursive step: If w is a palindrome and a is an element of Ʃ, then awa is a palindrome.
    iii) Closure: w is a palindrome only if it can be obtained form the basis elements by a finite number of applications of the recursive step.
    The set of palindromes can also be defined by {w | w = w^R }. Prove that these two definitions generate the same set.
    (w^R means the reversal of w)
    2. Relevant equations
    3. The attempt at a solution
    I don't have an attempt because I'm not sure how to start the proof. Do I prove this the same way I would prove the associative law of sets, or would I prove this using induction?
Draft saved Draft deleted
