Searching for Quiet Battery Operated Smoke Detectors
In summary: Brits are nice sensitive gentle people and manage crisis situations with tender loving persuasion....which makes them useless in a dealing with a crisis situation?
wolram
Dearly Missed
4,446
558
The little round battery operated one's, has anyone found one that doe's not sound off
at the slightest whiff from the cooker, i mean i have one in my living room that is yards away from the cooker and that sounds off with no visible smoke about, even the one upstairs
has gone off a few times.
And it is not my cooking, the last thing i burnt was months ago.
wolram said:
The little round battery operated one's, has anyone found one that doe's not sound off at the slightest whiff from the cooker,
But then how would you know that tea is ready?
You aren't supposed to put them in kitchens for this reason (which is a bit daft cos that's where all the fires start!). Time to clean the oven?
My cooker is clean as a whistle, it should be i spend as much on oven cleaner as i do food.
I think you got it right, it is more a food ready alarm rather than a fire alarm, and i do clean the alarm often, i would chuck the things out, but i bet a pound to a penny i would have a real fire the next day.
We resolved this scenerio, by installing the smoke detector in the room next to kitchen. If cooking odours were strong enough to set it off, we closed the door between the kitchen & adjacent room.
It could be due to the dust in your house?Are you a bit advanced in years and do you suffer from dust?My wife has to dust me off every time I go out.I quite enjoy it when she uses a feather duster
I had to remove my smoke alarm and install a heat alarm. I still have a smoke alarm in my sleeping area and laundry room. The heat alarm, goes off only when a certain temp is reached, its also tied in with my home alarm system, which automatically calls the fire department.
http://en.wikipedia.org/wiki/Heat_detector
That sounds dangerous hypatia.I would have thought that any fire would be well underway before a heat alarm is triggered.
I thought the smoke alarms were tuned to a particular particle size, so they are supposed to trigger from a smoldering foam sofa before you can see any smoke.
I remember we had to have different ones fitted in offices where presumably paper is a big risk than in a workshop where it was burning electricals.
About 15 years ago a friend of mine was making his living by repairing some strange electronic devices. Once he was given a bunch of gas detectors to clean, repair, adjust - whatever. It seemed to him they were all sensitive to nothing. Then he decided to use them at lowest sensitivity setting and walk his house. He found a gas leak.
Because alpha particles are so easily absorbed I do not think that particle size would be very relevant -I may be wrong.Most,if not all of the alarms sold in the UK use americium 241 as the source this having a long half life.
That was the point, one of them had to be an optical smoke detector and the other could be a regular Americium one. I can't remember which way round it was though!
Yes I suppose an optical one could cover a larger area or something similar.
Don't tell me Brits are not able to make their own detectors.
Because all the British isotopes are perfectly stable, they don't go firing off particles at the slightest provocation.
crisis? what crisis?
in case of fire, shout 'fire"!
and what's all the fuss? :confused:goldfish don't have fire alarms anyway :smile: …​
tiny-tim said:
in case of fire, shout 'fire"!​
Shout? I don't think so.
I think a British smoke alarm would just cough - discreetly.​
in case of fire shout "fire"
ah … that's exactly why we English (I don't know about the Scots and the Welsh, and I'm pretty sure it doesn't apply to the Northern Irish!) have to be told to shout …
English hotels and barracks and so on always have notices saying "in case of fire shout fire", otherwise it would never occur to us! :smile:
1. What is the importance of having a quiet battery-operated smoke detector?
Having a quiet battery-operated smoke detector is important for several reasons. First, it ensures that the detector will not disturb the occupants of the building with unnecessary noise. Second, it allows for early detection of smoke, which is crucial for fire safety. Third, it provides peace of mind knowing that the detector is functioning properly without constantly beeping or chirping.
2. How do battery-operated smoke detectors differ from hardwired smoke detectors?
Battery-operated smoke detectors are powered by batteries, while hardwired smoke detectors are connected to the building's electrical system. Battery-operated detectors are more portable, making them suitable for rental properties or homes without hardwired systems. However, hardwired detectors do not require battery replacements and can interconnect with other detectors in the building.
3. Do quiet battery-operated smoke detectors have the same level of sensitivity as regular detectors?
Yes, quiet battery-operated smoke detectors have the same level of sensitivity as regular detectors. The difference lies in the sound level of the alarm, not the detection capability. They are designed to detect smoke particles in the same way and should be tested and maintained regularly to ensure proper functioning.
4. Can quiet battery-operated smoke detectors be interconnected with other detectors in the building?
Yes, many models of quiet battery-operated smoke detectors can be interconnected with other detectors in the building. This allows for a more comprehensive and efficient detection system. However, it is important to check the manufacturer's specifications to ensure compatibility and proper installation.
5. How often should the batteries in a quiet battery-operated smoke detector be replaced?
The batteries in a quiet battery-operated smoke detector should be replaced at least once a year. It is recommended to replace them twice a year, usually when daylight saving time begins and ends. However, if the detector is beeping or chirping, it may be a sign that the batteries need to be replaced sooner. It is important to always have spare batteries on hand in case of emergency.
  • General Discussion
  • Other Physics Topics
  • General Engineering
  • Computing and Technology
