Firefox doesn't work
  1. Jan 11, 2012 #1
    Anyone else having a problem with PF in firefox? It works fine in IE (but I hate IE...)
    When I try it in firefox I get this message:
    Method Not Implemented
    GET to /showthread.php not supported.
    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
  3. Jan 11, 2012 #2
    jedishrfu
    Staff: Mentor
    you must have a bad url or something. 404 errors come up because of that. the .php file is a server-side file so I think the server is confused about your url try using www.physorg.com to get to the physicsforums.com or type in the www.physicsforums.com by itself.
    I tried it on firefox on linux and it worked just fine. version # is 3.6.24
  4. Jan 11, 2012 #3
    Simon Bridge
    Have you tried deleting your cache and cookies?
  5. Jan 11, 2012 #4
    I've been using Firefox for years here without issue.
    Try clearing your cache:
    Tools > Options > Advanced > Network > Clear Now
    Failing that, try running Firefox in Safe Mode:
    http://support.mozilla.org/en-US/kb/Safe Mode
    If it works in safe mode, then an extension is probably to blame.
  6. Jan 11, 2012 #5
    That did it, thanks.
    What is weird is that it stopped working today on both my home and work computers. Different ISP, FF version and OS...
  7. Jan 11, 2012 #6
    jedishrfu
    Staff: Mentor
    True but same operator
  8. Jan 11, 2012 #7
    OK, what did I do to make it quit? It wasn't a bad URL since I'm using a bookmark in both cases under FF and by purging the cache it works.
  9. Jan 11, 2012 #8
    Simon Bridge
    Google the error message and you'll see.
  10. Jan 15, 2012 #9
    nvn
    matthewdb: Exactly what url are (were) you using in your Firefox bookmark?
  11. Jan 15, 2012 #10
    I have a similar problem that the site ceases to work with certain browsers.
    I am pretty sure it's a combination of the stored profile (probably some cookie,) and the advertisements. It happens on other sites too.
    My theory, at the moment, is that for my current profile the advertisement server either stalls or redirects to very slow sites, freezing the rendering process of PF web pages.
    You might want to check whether you have the same problem by wiping all profiles/cookies under Firefox and see whether you can load the pages then. (I don't because I am too lazy to restore all passwords stored, so I usually switch browser.)
  12. Jan 15, 2012 #11
    I am going to the main page:
    https://www.physicsforums.com/
    It will work for a while if I clear the cache and then it will quit on my next visit. I've just started using private mode and then it works fine. Private mode doesn't allow websites you are browsing to see your cookies so I'm sure it's a cookie problem with PF.
  13. Jan 15, 2012 #12
    PAllen
    Actually, private browsing in Firefox does not change your cookie policy at all. It allows sites to do whatever is allowed by your normal cookie policy (including any exceptions you've set up); this also applied to the infamous flash cookies. Instead, what it ensures is that all cookies (including flash cookies) materialized during the session are deleted on termination. (Of course, it also deletes history and cache used in the session as well).
    Given that this solves your problem you might want to try setting a cookie exception for physics forums that keeps cookies only for the session (downside - you will have to log in every time).
    Personally, I disable cookies by default for all sites, and allow them only for sites that I want. This gets rid of all advertising cookies from associated advertising sites. I also completely disable flash cookies and refuse to use sites that require them (this you can't do from firefox; googling should get you instructions for this, if desired).
    However, in your case you might say it is too late for this approach because you have too many cookies remembering logins that you don't want to lose.
    Pick your poison.
    [Edit: I realize that even before I became a paid member I never got ads because of security addons I have in firefox; not primarily adblockers (though those exist), but many ads are eliminated due to security policies). So if your problem is ad related, I never had it. I would not want to recommend ad blockers. Instead, I encourage contributing to this site.]
  14. Jan 16, 2012 #13
    nvn
    matthewdb: Your url looks good, I think. The software may have changed since then, but in the past, the PF software sometimes exhibited strange bugs if you omitted the "www." This is mentioned in post 2936816.
Similar Discussions: Firefox doesn't work
Loading...
