Firefox Pipelining - Speed Up Your Browsing!
  • Thread starter hitssquad
  • Tags
    Firefox
In summary: I have a T1 campus connection, my guess is you ahve something similar and that the connection is already so fast that the impact is minimal.Although in my opinion this should be something that should be controlled from the server, it is not typically...Anttech,That is entirely false. Pipelining does not use more than one connection; it simply queues up more than one request at a time on a single keep-alive connection. This way, you can drop three or four requests onto a server all in one packet, reducing the effect of packet latency. It doesn't stress sites any more than any other method of retrieving pages; it just makes the requesting more efficient. Firefox's default setting is to open no
hitssquad
927
http://www.theinquirer.net/?article=20453
  • Firefox flies into over drive
    Is it a bird... is it a plane..?
    By INQUIRER staff: Thursday 30 December 2004, 22:09
    ASK ANY OF FIREFOX'S avid supporters and they'll tell you it's the fastest browser around, true or not.
    Well, the INQ's stumbled on a little tweak that's easy to do and sends the browser into overdrive.
    All you've got to do is type "about:config" into your address bar, wait for it to load, then alter the following entries: change "network.http.pipelining" to "true", "network.http.proxy.pipelining" to "true" and lastly "network.http.pipelining.maxrequests" to 30, meaning it will be able to make 30 requests at once.
Computer science news on Phys.org
Wow, that does make firefox really fast.
Amazing! Try it!
Awesome, Thanks!
wow, makes a huge difference. What is the reason for this not being the default setting
Ok, I just found the problem pipelining. This is a bug that can be fixed, but when you go to sites that stream media you start to hear echos because it is downloading the media over and over again.
Changed "network.http.pipelining.maxrequests" value to 25 and was able to view streaming media with no problem.
Very cool, not sure why this is not the default, pipelining has been around ever since HTTP 1.1
I hate to be the only contrarian here, but what are those config changes supposed to accomplish? I tried it and I didn't notice any change. So I tried switching the settings a few times, on, off, on again, off again; Firefox is real fast either way, and I can't see any difference related to those settings.
Does it help with certain kinds of content?
zippidy doo daa! thanks hitssquad
The weird thing is it keeps going back to the default settings.
by the way, you may get banned from some smaller sites if you use this functionality, as you are in escence using more connections to the server to render objects etc (more pipes so instead of using 3 connections you are using 8 or something like this). So you can Max out server connections and bring sites down if everyone was doing this...
Anttech,
That is entirely false. Pipelining does not use more than one connection; it simply queues up more than one request at a time on a single keep-alive connection. This way, you can drop three or four requests onto a server all in one packet, reducing the effect of packet latency. It doesn't stress sites any more than any other method of retrieving pages; it just makes the requesting more efficient. Firefox's default setting is to open no more than two simultaneous connections to anyone server, and pipelining does not change this.
- Warren
I'll ask again: do I have to be downloading some particular kind of content in order to notice any benefit from pipelining? (Or do I need a slower connection?)
I tried changing the settings as described but didn't see any difference.
I ahven't noticed any particular change either. But i have a T1 campus connection, my guess is you ahve something similar and that the connection is already so fast that the impact is minimal.
The sites that will benefit most from pipelining are those with lots of individual elements, such as inline graphics, flash animations, frames, and so on. If you already have a low-latency connection, you may not notice much of a difference. If you are on a high-latency connection, like a modem, the difference can be substantial.
- Warren
1. What is Firefox pipelining?
Firefox pipelining is a feature that allows the browser to send multiple requests to a server at once, instead of waiting for each request to be completed before sending the next one. This can significantly improve browsing speed and performance.
2. How does Firefox pipelining work?
Firefox pipelining works by sending multiple HTTP requests to a server at once, instead of waiting for each response before sending the next request. This reduces the amount of time the browser has to wait for a response, resulting in faster browsing speeds.
3. Is Firefox pipelining enabled by default?
No, Firefox pipelining is not enabled by default. Users can enable it by typing "about:config" in the address bar, searching for "network.http.pipelining", and setting the value to "true". However, it is important to note that enabling pipelining may not always result in faster browsing speeds and may even cause compatibility issues with certain websites.
4. Are there any risks associated with using Firefox pipelining?
There are potential risks associated with using Firefox pipelining, such as compatibility issues with certain websites and increased server load. It is important to carefully consider the potential risks and benefits before enabling pipelining.
5. Can Firefox pipelining be used with all types of internet connections?
No, Firefox pipelining may not work with all types of internet connections. It is most effective with high-speed connections, such as broadband or fiber optic, and may not make a significant difference with slower connections.
