I: Fireplace Inserts for 1940's Colonial
  • Thread starter DocToxyn
In summary: I always thought fireplaces were more decorative and coziness makers than house heaters. In summary, the fireplace is too small and most of the advertised inserts won't fit. The hole could be cut out to make a larger opening, but custom doors may be necessary.
DocToxyn
We just recently moved into a 1940's Colonial that is centered around the fireplace/chimney. Right now, it's way too inefficient to heat the house with the fireplace as it is, so I've looked into inserts. The problem I'm having is that it is apparently a small fireplace (front opening ~24" square and it tapers to even smaller in the back) and most of the advertized inserts won't fit. Does anyone know if the hole could be cut out to make a larger opening, are there smaller inserts I haven't found yet? Any advice or directions to resources would be greatly appreciated. Thanks.
DT
Hit the appliance stores. If you can find a "mom and pop" that ain't been run out by the big boxes, they'll have sources and catalogues from those sources to fit just about anything.
DT
You may need to get custom doors. I recommend Thermo-Rite.
This link has the heater grates in 22" & 20"
40,000 BTU's of heat per hour -
100 CFM blower (variable speed) -
Rheostat and Thermostat controlled -
Turns on automatically at 110° and of at 90° Motor on right and black riser is standard.
Steel tubing warranted for 3 years
Electrical components are UL approved and 1 year warranty. Shipping weight 52 lbs.
Available Sizes:
TR-22 = 24" W x 22" D
TR-20 = 22" W x 20" D
TR-17 = 20" W x 17" D
http://www.thermo-rite.com/
Couldn't you just marinate your logs in napalm?
While I do 'love the smell of napalm in the morning', it gets a little cloying around 2:00 pm.
Right... I can see the dilemma there. Hmmm... let me think on it for a while and I'll get back to you.
With a house that age, I'd recommend you have a masonry expert come out and check your fireplace and chimney to make sure it's in good working condition. Tiny cracks in the chimney can lead to big house fires or carbon monoxide exposure (your home inspector may or may not have given that attention during the pre-purchase inspection). They can also look at the construction and let you know if it's possible to widen the fireplace without compromising it's structural integrity...there would be no way for us to know without being able to look at it, though my guess is that it probably can't be done without making it unstable.
build your own inserts, how hard could it be?
I happen to know that 2L bottles of pop hold onto their heat pretty well if you want to integrate them into your plan
On a serious note, you are talking a major job if you want to make the fireplace bigger than it is. When I was growing up we heated our basement with a wood stove and never used our fireplace at all. I always thought fireplaces were a lot more decorative and coziness makers than house heaters. Isn't just about any other choice you could make cheaper and more efficient?
:rofl: Yes, yes, tribdog definitely speaks from experience there! :rofl:
If you really want to heat your house with the fireplace be prepared to spend a fortune on those little portable heaters you plug into the wall. because that's the only way you are heating the entire house. YOu'll end up roasting in the living room and freezing in all the others. And splitting wood sucks, and carrying wood in from outside sucks and waiting for some heat first thing in the morning sucks.
My parents used to heat the house in the winter with a wood stove. The only minor problem was that MY bedroom was the furthest from the stove. :grumpy: And of course, out of everyone in the house, I was the one who liked it warmest. :grumpy: :grumpy: I started dragging my pillow and blanket out to sleep in front of the stove on the living room floor because I was too frozen to sleep in my room. But my parents still said they loved me. :uhh:
awww poor Moonbear. :cry:
You can't heat a house with a single fireplace unless your house is one small room. I remember trying to sleep at a friend's lake house one winter and there was only a wood stove in the living room, it was probably 30 F degrees in the bedroom and it was only a bit colder outside. :bugeye:
Or your name is Charles Ingalls. I'm pretty sure he heated the entire little house pretty well, but Pa could do anything.
1. What are fireplace inserts for 1940's colonial homes?
Fireplace inserts for 1940's colonial homes are specially designed fireplaces that can be inserted into an existing fireplace opening. They are typically made of cast iron or steel and are used to improve the efficiency and appearance of the fireplace.
2. How do fireplace inserts for 1940's colonial homes work?
Fireplace inserts work by capturing and circulating the heat produced by the fire. They have a closed combustion system that allows for better control of the fire and increases the amount of heat that is released into the room.
3. What are the benefits of using a fireplace insert for a 1940's colonial home?
There are several benefits to using a fireplace insert for a 1940's colonial home. These include increased energy efficiency, improved heating capabilities, and a more modern and attractive appearance for the fireplace.
4. Can fireplace inserts be installed in any 1940's colonial home?
Yes, fireplace inserts can be installed in most 1940's colonial homes. However, it is important to ensure that the insert is the correct size and type for the existing fireplace opening. It is recommended to consult with a professional before installation.
5. How do I maintain and clean a fireplace insert for a 1940's colonial home?
Maintenance and cleaning of a fireplace insert for a 1940's colonial home is important for both safety and efficiency. It is recommended to regularly clean the insert and have it inspected by a professional at least once a year. Proper use and disposal of ashes is also crucial in maintaining the insert.
  • Mechanical Engineering
  • Math Proof Training and Practice
10K
  • STEM Career Guidance
  • General Discussion
  • Beyond the Standard Models
