First Derivative
  • Thread starter DollarBill
Find the first derivative for
x sin(y) = y cos(x)
x sin(y) = y cos(x)
Product rule on each side:
x cos(y) + sin(y) = -y sin(x) + cos(x)
I'm not sure what to do after that or if if I was even doing it right to begin with.
Answers and Replies
HallsofIvy
41,847
966
x sin(y) = y cos(x)
x sin(y) = y cos(x)
What are you differentiating with respect to- x or y? It must be one or the other. If you are differentiating with respect to x, then the derivative of sin(y) is NOT cos(y), it is, by the chain rule, cos(y)(dy/dx) and the derivative of y is NOT 1, it is dy/dx. If you are differentiating with respect to y, then the derivative of x is NOT 1, it is dx/dy, and the derivative of cos(x) is NOT -sin(x), it is -sin(x)(dx/dy).
Finally, what does the problem really say? I am sure that it does not say "Find the first derivative for x sin(y) = y cos(x)", that doesn't make sense. I suspect it said "Find the derivatvive of y if x sin(y)= y cos(x)" though I can't be sure.
This is all it says:
It does have answer choices, but they don't have any equal signs in them. They don't say "dy/dx =" or "dx/dy =". Here are the answer choices:
A) Sin(x) - x sin(y) / y cos(x) - cos(y)
B) cos(x) - sin(y) / sin(x) - cos(y)
C) y sin(x) + sin(y) / cos(x) - x cos(y)
D) sin(x) + sin(y) / cos(x) + cos(y)
E) None of the above
gabbagabbahey
I'm sure that they want you to find [itex]dy \over{dx}[/itex] by implicit differentiation.
Working it out again for dy/dx:
dx/dx Sin(y) + x cos(y)dy/dx = dy/dx cos(x) - y sin(x)dx/dx
dx/dx just goes to 1:
I'm pretty much where I was before except with a dy/dx on each side that would just cancel each other out.
gabbagabbahey
The [itex]dy \over{dx} [/itex]'s don't "cancel each other out". There are two terms on each side of your equation, and only one term per side has [itex]dy \over{dx} [/itex] as a factor...Try isolating the terms with [itex]dy \over{dx} [/itex] on one side of the equation, and the rest of the terms on the other.
Sin(y) + x cos(y)dy/dx + y sin(x) / cos(x)= dy/dx
How would I get rid of the 2nd dy/dx? :confused:
Well seeing as there's no dy/dx in the answer, I tried to do the following:
dy/dx = -sin(y)/x cos(y)
dy/dx=y sin(x) / cos(x)
-sin(y)/x cos(y) = y sin(x) / cos(x)
Cross multiply to get:
y sin(x)*x cos(y) / cos(x)*-sin(y)
But it's still not an answer choice
gabbagabbahey
Let's start again from here:
[itex]dy \over{dx} [/itex] is a variable, and it happens to be the variable you are trying to solve for in the above equation.
Start by moving the terms that have [itex]dy \over{dx} [/itex] in them to one side of the equation and move the terms that don't have [itex]dy \over{dx} [/itex] in them to the other side.
For example, if I had the equation [itex]Ax+sin(y) \frac{dy}{dx}=By\frac{dy}{dx}-3cos(x) [/itex], I would solve it as follows:
Step 1; isolate the terms with [itex]dy \over{dx} [/itex]:
[tex]Ax+sin(y) \frac{dy}{dx}=By\frac{dy}{dx}-3cos(x) \Rightarrow sin(y) \frac{dy}{dx}-By\frac{dy}{dx}=-Ax-3cos(x)[/tex]
Step 2; factor out a [itex]dy \over{dx} [/itex]:
[tex]sin(y) \frac{dy}{dx}-By\frac{dy}{dx}=-Ax-3cos(x) \Rightarrow \frac{dy}{dx}(sin(y)-By)=-Ax-3cos(x) [/tex]
Step 3: divide by [itex](sin(y)-By)[/itex] and hence solve for [itex]dy \over{dx} [/itex]:
[tex]\frac{dy}{dx}=\frac{-Ax-3cos(x)}{(sin(y)-By)} [/tex]
and so my answer would be [tex]\frac{-Ax-3cos(x)}{(sin(y)-By)}[/tex]
Apply this method to your problem.
y sin(x) + sin(y) / cos(x)-x cos(y)
Wow, that was really easy. I was way over thinking that one :yuck:
Thanks
gabbagabbahey
Thanks
Yep :approve:
Related Threads on First Derivative
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
26K
