First order linear diff eq
In summary, the conversation discusses the steps involved in solving a differential equation, specifically the process of multiplying both sides of the equation with a function v(x) and integrating both sides. The need for understanding the notation and concepts of elementary calculus is also emphasized.
robertjford80
388
I don't understand why in step 2 dy turns into d and why +P(x) dissappears
I also don't see a difference between v(x)y and v(x)*y
In step three why does the d disappear. I see that dx is going over to the right side, well, what about the numerator d?
d/dx is the differential operator. dy/dx just means d/dx operating on y. You should probably read a bit more elementary calculus to get used to this notation.
You start from a differential equation
[tex] \frac{dy}{dx} + P(x) y = Q(x) [/tex]
and then you multiply both sides of this equation with a function [itex]v(x) [/itex] (which you have to find first) which has the property that the left hand sides of steps 1 and 2 are equal.
In step 3, you integrate both sides of the equation with respect to x.
1. What is a first order linear differential equation?
A first order linear differential equation is an equation that relates an unknown function with its first derivative. It can be written in the form of y' + p(x)y = q(x), where p(x) and q(x) are functions of x.
2. How do you solve a first order linear differential equation?
The general solution to a first order linear differential equation can be found by using an integrating factor, which is a function that multiplies both sides of the equation to make it easier to solve. The integrating factor is e∫p(x)dx, and once found, the solution is given by y = 1/IF * ∫IF * q(x)dx + c, where IF is the integrating factor and c is the constant of integration.
3. What is the difference between a first order linear differential equation and a first order non-linear differential equation?
A first order linear differential equation has a constant coefficient for the highest order derivative, while a first order non-linear differential equation has a variable coefficient for the highest order derivative. This means that the unknown function and its derivatives are linearly related in a first order linear differential equation, while they are non-linearly related in a first order non-linear differential equation.
4. How do you apply initial conditions to a first order linear differential equation?
To apply initial conditions, you simply substitute the given values of the unknown function and its derivative into the general solution. This will give you a specific solution that satisfies the given initial conditions.
5. What are some real-life applications of first order linear differential equations?
First order linear differential equations are commonly used in physics and engineering to model processes such as growth, decay, and heat transfer. They are also used in economics to model population growth and interest rates, and in biology to model population dynamics and chemical reactions. Many other fields also use first order linear differential equations to describe various phenomena.
