First order ODE IVP use in Heat equation of ball with heat source.
  1. Jun 29, 2010 #1
    This should be a simple ODE problem inside Heat problem of ball with steady state heat source. I am going to present the question first and then I am going to put in a little bit of the formulas to bring this into the big picture:
    [tex] B'_{jnm}(t) + \lambda^2_{nj} c^2 B_{jnm}(t) = q_{jnm} [/tex] (1)
    and
    [tex] B_{jnm}(0)= f_{jnm}[/tex](2)
    I want to solve for [itex]B_{jnm}(t)[/itex].
    (1) and (2) form a simple first order ODE with initial value problem. I cannot get the result from the book. This is my derivations:
    Using variation of parameter: Let [itex] B_{jnm}(t)= B_{jnmc} + B_{jnmp} [/itex]
    [itex]B_{jnmc} [/itex] is solution of associate homogeneous equation and [itex]B_{jnmp} [/itex] is the particular solution of the non-homogeneous DE.
    [tex]B'_{jnmc} + \lambda^2_{nj} c^2 B_{jnmc} = 0 \Rightarrow\; B_{jnmc} = C_1 e^{-\lambda^2_{nj} c^2 t} [/tex]
    [tex] B_{jnmp} = u B_{jnmc} = u C_1 e^{-\lambda^2_{nj} c^2 t} [/tex]
    [tex] B_{jnmp} = C_1 e^{-\lambda^2_{nj} c^2 t} \int \frac{g_{jnm}}{C_1} e^{\lambda^2_{nj} c^2 t} dt = C_1 [\frac{g_{jnm}}{\lambda^2_{nj} c^2}] [/tex]
    [tex] B_{jnm}(t) = B_{jnmc} + B_{jnmp} = C_1 e^{-\lambda^2_{nj} c^2 t} + \frac{g_{jnm}} {\lambda^2_{nj} c^2} [/tex]
    Initial condition:
    [tex] B_{jnm}(0) = f_{jnm} = C_1 + \frac{g_{jnm}} {\lambda^2_{nj} c^2} [/tex]
    [tex] \Rightarrow C_1 = f_{jnm} - \frac{q_{jnm}} {\lambda^2_{nj} c^2} [/tex]
  3. Jun 29, 2010 #2
    I found out what I did wrong already. It was so stupid!! I forgot the constant. I'll edit the original post.
    Please ignor this. Thanks
    Moderator, if you can, please delete this entire post.
