Homework Help: First order ODE.
  1. Nov 25, 2013 #1
    Find the general solution of 2y' + y - (2y')*ln(y') = 0
    2. Relevant equations
    3. The attempt at a solution
    I have no idea how to deal with this i mean none of the first order techniques work and it's mainly because I don't know how to deal with the ln(y').
    I tried seperating the ln to lndy - lndx but it didn't do any good.
  3. Nov 25, 2013 #2
    I think a reasonable first step is to differentiate the whole equation once. That should make the logarithm term more approachable.
  4. Nov 25, 2013 #3
    Seemed like a good idea but when I differentiated I feel like I complicated it even more by increasing the order
    dy/dx (2y' + y - (2y') * ln(y') = 0)
    2y" + y' - 2y" * ln(y') - 2y'*y''/y' = 0
    = 2y" + y' - 2y" * ln(y') - 2y''
    = y' - 2y" * ln(y')
  5. Nov 25, 2013 #4
    That's how it may seem, but look closer. It's actually a first order ODE for y', and now the logarithm term makes much more sense. There's an obvious substitution you can make to simplify the equation further.
  6. Nov 25, 2013 #5
    r = y'
    dr = y"
    r - 2dr * ln(r) = 0
    I feel like something is wrong here maybe I differentiated r incorrectly?
  7. Nov 25, 2013 #6
    Mark44
    Staff: Mentor
    In the first line above, your notation indicates that you are multiplying an equation by dy/dx. What you're actually doing is taking the derivative of each side of an equation.
    This notation -- dy/dx(x2) -- means the derivative of some unknown function times x2. Without knowing what dy/dx is, it can't be further simplified.
    This notation -- d/dx(x2) means the derivative, with respect to x, of x2, which is 2x.
    Your 3rd and 4th lines should be their own equations, with 0 on the right side.
  8. Nov 25, 2013 #7
    Sorry you're right.
    2y" + y' - 2y" * ln(y') - 2y'' = 0
    y' - 2y" * ln(y') = 0
  9. Nov 25, 2013 #8
    Mark44
    Staff: Mentor
    Yes, instead of dr = y'' you should have dr/dy = y'' or r' = y''.
    Using the tip from clamtrox, if you let u = y', so u' = y''. This will give you a first order DE in u that is separable.
  10. Nov 26, 2013 #9
    So it would become . . .
    r dy - 2 (ln(r)) dr = 0
    since r = y'
    int ( y'dy) - 2 int (ln(r)) dr) = 0
    Is that right?
  11. Nov 26, 2013 #10
    No, that makes no sense. Let's say y is a function of a variable called x. Then y' = dy/dx. This is also a function of x. Now you say r = y'. Also r is a function of x. So your equation is r - 2 dr/dx * ln(r) = 0. Now you can move all r's on one side, and all x's on the other side, and integrate.
  12. Nov 27, 2013 #11
    So after integrating r - 2 dr/dx * ln(r) = 0
    I get x - 2ln(ln(r)) = 0
    x - 2ln(ln(y')) = 0
    x = ln(ln(y')^2)
    e^x = (ln(y'))^2
    I got stuck here not sure how to seperate the y.
    Sorry about replying so late every time it's cause of the time zone.
  13. Nov 28, 2013 #12
    Something goes wrong here. The integration is very straightforward if you substitute z = ln(r).
  14. Nov 29, 2013 #13
    This was after the integration.
    This is what I integrated.
Have something to add?
Draft saved Draft deleted
