What Are the Properties of First and Second Derivatives?
However, you might want to note that the critical point at x = 0 is a point of inflection, not an extremum.
Qube
http://i3.minus.com/j7uTkNLAl2aBy.png
Extrema occur at critical points; critical points are either where the first derivative fails to exist or equals 0.
Horizontal tangent lines occur where the first derivative is 0.
Points of inflections occur when the concavity changes across a point.
14) Yes, the original function has a horizontal tangent line at x = 2. The graph of the derivative is 0 at the specified point. The original function also has an inflection point because the derivative of the derivative changes sign from positive to negative.
15) No, the derivative is negative at x = -2 (the second tick mark on the x-axis to the left of the origin). It is concave up however since the derivative of the derivative is positive.
16) x = 0 is a critical point since the derivative is going to the infinities. However, the derivative to the left is positive; the derivative to the left is negative. It's a local maximum.
17) Yes; the second derivative is negative only from 2 to infinity.
Corrected version:
Extrema occur at critical points; critical points are points in the domain of the function either where the first derivative fails to exist or equals 0.
I'm afraid you're missing some important ideas here. All of your answers are wrong.
The function does have a horizontal tangent at x = 2, but there is NOT an inflection point here. An inflection point has to do with the second derivative changing sign, not the first derivative.
No, the derivative is positive at x = -2. Notice that the derivative is positive all along the graph for x < 0. You should be able to look at the graph and see that the branch on the left is concave up and increasing.
The function is not defined at x = 0. A critical point has to be in the domain of the function - 0 is not in the domain of this function, so isn't a critical point, and isn't a local maximum. There are no local or global minima. The local maximum is at x = 2. There is no global maximum.
Not true, because that's not the only interval. By inspection, you should be able to notice that the graph is concave down for x > 0.
Wait. That is the graph of f'(x) not f(x). I know it's a bit small and I'm trying to upload another picture right now. I really appreciate your going through my answers and I apologize since the little prime symbol is difficult to see in the original picture.
http://i3.minus.com/jbwsxB4NOJKivj.bmp
Mark44 said:
Corrected version:
Correct. Critical points must exist in the domain of the original function. E.g. consider f(x) = 1/x. f'(x) = -x^-2. x = 0 appears to be a critical point but it does not exist in the domain of 1/x so it cannot be a critical point.
OK, that changes things. I couldn't tell that what you first posted was the graph of f'. I'll take another look at your answers and get back to you.
In light of the fact that the graph was of f', your answers seem correct to me.
What is a first derivative?
A first derivative, also known as the derivative, is a mathematical concept that represents the rate of change of a function at a specific point. It is the slope of the tangent line to the function at that point.
What is a second derivative?
A second derivative is the derivative of a derivative. It represents the rate of change of the first derivative at a specific point. It can also be thought of as the curvature of the function at that point.
What is the relationship between the first and second derivatives?
The first derivative indicates the slope of the function, while the second derivative indicates the concavity of the function. A positive first derivative means the function is increasing, and a positive second derivative means the function is concave up. Similarly, a negative first derivative means the function is decreasing, and a negative second derivative means the function is concave down.
How do you find the first and second derivatives of a function?
The first derivative can be found by taking the derivative of the function using the rules of differentiation. The second derivative can be found by taking the derivative of the first derivative. It is important to note that the order of differentiation matters, so the second derivative may be different depending on which variable is being differentiated first.
What are the applications of first and second derivatives in science?
The first and second derivatives have many applications in science, including physics, chemistry, biology, and economics. They can be used to analyze motion, calculate rates of change, determine optimal solutions, and much more. In physics, the first derivative is used to calculate velocity and the second derivative is used to calculate acceleration. In economics, derivatives are used to model and predict financial markets.
