Fit with implicit functions?
  • Thread starter P3X-018
P3X-018
144
Is it possible to make a least squares fit with a function given implicitly, because the equation isn't solveable analyticly? Because I had the coupled ODE,
[tex]\ddot{x} = \omega^2x + 2\omega\dot{y} - C\,\frac{\dot{x}}{\dot{r}}[/tex]
[tex] \ddot{y} = \omega^2y - 2\omega\dot{x} - C\,\frac{\dot{y}}{\dot{r}} [/tex]
where [itex] \dot{r} = \sqrt{\dot{x}^2+\dot{y}^2}[/itex], and [itex] \omega [/itex] and C are constants in time.
I can numerically solve this system and make a plot in x-y, but I also have some measurement data, so is there a way to make best fit of the "solution" to the data points? That is vary the 2 constants to make a best fit?
There are also the 4 initial conditions when solving this system of ODE, how will they be involved in this?
Answers and Replies
fresh_42
Mentor
Insights Author
2021 Award
17,606
18,178
Of course you can measure the distance between your measurement data and the solution you calculated. I would use regression methods, depending on the degree of the solution. The origin of the data (the ODE solution) shouldn't bother you. If you want to calculate the constants by a best fit you will get an optimization problem, which probably needs again a numerical solution.
Suggested for: Fit with implicit functions?
  • Last Post
  • Last Post
MHB Functions
  • Last Post
  • Last Post
  • Last Post
  • Last Post
