Fix CD Skips?
  • Thread starter lisab
lisab
Staff Emeritus
617
I found some of my CDs in a box that had been rolling around in the back of my daughter's car. They were pretty scratched up :cry: and skip a lot.
I googled "fix CDs" and got lots of stuff that look like scams. Some of the "fixes" they recommend I'm sure could ruin the surface (emery cloth...errrm, not so sure...).
So what works? If possible I'd like first-hand experiences with this.
Answers and Replies
Moonbear
Staff Emeritus
53
I've heard that you can sometimes fix a scratch by filling it in with a grease pencil, but I've never tried it. I doubt that there's much that can be done to fix it other than replace the CDs.
Read that
http://www.wikihow.com/Fix-a-Scratched-CD
Basically I think your best bet is to try to clean it up and then rip it and re-burn
EDIT - The lingo: "rip" means read the data onto a computer and "burn" means create a new CD from the data ;)
negitron
Anything that polishes the surface sufficiently can mitigate or entirely remove scratches, depending on their severity. A CD is a disk of polycarbonate plastic with the pits and grooves which comprise the data track pressed into the upper surface. This surface is then metal plated (usually with aluminum), lacquered and imprinted with the label. What all this means is that you've got nearly two millimeters of hard, clear plastic protecting the delicate data. The bad news is that the label side is very easily damaged because it's just a few thin layers of lacquer and ink. Once that side is scratched, your disc is hosed. It's easy to check this: hold the CD up to a bright light source; if you can see any light through the disc surface, the scratch has penetrated the metallized layer and the CD can no longer be read in that spot. If you see lots of such spots, the disc will probably not play reliably, if at all. The most reliable and effective devices for polishing out scratches employs a radial (that is, from the center out, not along the direction of the track) polishing motion, such as http://www.compuplus.com/i-Memorex-32028007-Optifix-Motorized-CDDVD-Cleaner-and-Scratch-Repair-Kit-1007658~.html [Broken].
I had the same thing happen with one of my cds. It was in the back of my car and got really scratched up. Some of my rather scratched up CDs my computer can still scan but that didn't work on this one. You can try the computer and maybe burn a new copy if that works.
What I did was find and download a copy. I know we aren't supposed to support anything illegal here but technically downloading a copy of a CD you own isn't necessarily illegal. If the Mentors prefer this not be said here anyway then by all means edit it out or ask me to and I will do it.
russ_watters
Mentor
21,071
7,806
The devices they sell at music stores to polish them do work, but they won't remove deep scratches. I'd try one of the recommendations for filling any deep scratches after polishing away the little ones.
I read somewhere, ages ago, that brasso works better than most of the special cd cleaning solutions. I've used it on some of my own cds, most of them were too scratched up to be saved but some of them did seem to get better.
Monique
Staff Emeritus
65
In the past I used a very fine (soft surface) nail file to polish the surface of a damaged CD and it worked.
Astronuc
Staff Emeritus
3,464
That's what we've done. We got a kit from somewhere, but I don't remember.
turbo
52
I use Rain-X. It works much of the time. Clean the CD with a mix of rubbing alcohol and water, dry the disk, then rub on some Rain-X with a soft cloth. Let it sit for a while, then wipe off the excess. Good luck.
A friend of mine swears by spray furniture polish, but the fragrance chemicals would do me in, so I tried Rain-X.
Related Threads on Fix CD Skips?
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
J
  • Last Post
19K
S
  • Last Post
  • Last Post
  • Last Post
