Can Gluing High Powered Magnets with Same Poles Together Create a Dipole?
  • Thread starter Dymium
  • Tags
    Magnets
In summary, by placing two high powered magnets with negative poles facing each other, adding strong adhesive and pressing them together, the magnets will undergo reconfiguration. The possibility of creating a dipole with both negative and positive poles on the same side depends on the specifics of the magnets' structure, shape, and size.
Dymium
If you take 2 high powered magnets let's say the size of a silver dollar and put both in a table vice with neg poles facing each other, add some strong adhesive (superglue, gorila glue) and crank them together till the cement dries, with the same poles pressed together will this cause reconfiguration of the magnets ? I read an article where someone had done a similar experiment and said that it created a dipole where both neg and pos were on the same side ? Anyone have experience in magnetism?
Dymium
Yes, it will cause the "reconfiguration" of the magnets! That happens whenever a magnet interacts with just about anythig - such as sticking one to the door of your refrigerator. :-)
As to whether you can get mixed polarity on the surfaces, that would depend on the details of the structure, shape and size of the magnets.
There are a few factors to consider when it comes to using high powered magnets in this way. First, the strength and orientation of the magnets will play a role in how they interact with each other. If the magnets are strong enough, they may be able to overcome the adhesive and repel each other, causing them to shift position. Additionally, the strength of the adhesive will also play a role in whether the magnets stay in place or shift.
In terms of creating a dipole, this is possible depending on the strength and orientation of the magnets. However, it's important to note that magnets have a north and south pole, and these poles cannot be changed or reconfigured. So while it may appear that both poles are on the same side, in reality, one pole is simply being masked by the other.
As for personal experience with magnetism, it's always important to exercise caution and follow proper safety protocols when handling high powered magnets. They can be dangerous if mishandled or if they come into contact with electronic devices or pacemakers. It's always best to consult with a professional or do thorough research before conducting experiments with magnets.
1. What are fixxed high powered magnets and how do they work?
Fixxed high powered magnets are powerful magnets that are used in various industries, such as manufacturing, medical, and research. They work by producing a strong magnetic field that can attract or repel other magnetic materials. This is accomplished by aligning the electrons in the magnet in a specific direction, creating a magnetic force.
2. How are fixxed high powered magnets different from regular magnets?
Fixxed high powered magnets are different from regular magnets in terms of their strength and durability. They are designed to have a stronger magnetic field, which makes them ideal for applications where a regular magnet would not suffice. Additionally, fixxed high powered magnets are made with stronger materials, such as neodymium or samarium cobalt, which allows them to maintain their magnetic strength for a longer period of time.
3. What are some common uses for fixxed high powered magnets?
Fixxed high powered magnets have a wide range of uses, including in magnetic levitation, electric motors, MRI machines, and in various industrial applications. They are also used in consumer products, such as speakers, hard drives, and magnetic closures on bags and purses. Additionally, fixxed high powered magnets are commonly used in experiments and demonstrations to showcase the power of magnetism.
4. Are there any safety concerns when handling fixxed high powered magnets?
Yes, there are safety concerns when handling fixxed high powered magnets. These magnets are extremely strong and can easily attract or repel other magnetic materials, which can cause injuries if mishandled. It is important to handle these magnets with caution and always keep them away from electronic devices, credit cards, and pacemakers.
5. Can fixxed high powered magnets lose their magnetism over time?
Yes, fixxed high powered magnets can lose their magnetism over time. This can happen due to exposure to high temperatures, strong vibrations, or being dropped or struck. However, with proper care and handling, these magnets can maintain their magnetic strength for a long time. It is also possible to re-magnetize these magnets if they do lose their strength.
  • Electromagnetism
14K
