Flat Ending Light Beam: Is it Physically Possible?
In summary, the conversation is discussing the concept of a "light-sabre" like effect where a round light beam of a certain diameter extends slowly and stops in midair, with a flat end. The idea is not scientifically accepted or reviewed and may be accompanied by various physical effects. However, this concept is not physically possible as light cannot extend slowly, and even if it could, it would not be visible. The concept may be achievable in movies or through holographic projection, but it does not fit within the rules of the forum.
Fizica7
62
This is sort of SF in the sense that it's not scientifically accepted or reviewed.
The "idea" comes from other people and it is that a usually round light beam of a certain diameter, like 30-50-100-similar cm diameter, extends slowly and even stops midair. It's flat at the end.
Like a straight cylinder of semi transparent colored light with a perfectly straight 90 degree bottom end.
It's the physically possible? How?
PS: might be accompanied with various physical effects such as appearing to be solid or semi solid in nature, not blinding, no heat.
Are you thinking of an effect like a light-sabre only more geometrically precise?
The short answer is "no". But you knew that already when you said, "not scientifically accepted or reviewed".
Basically, light cannot extend slowly. Even if you did get what you asked for, nobody would be able to see it unless some light was not confined to the cylinder. However, the appearance of what you were after is acheivable... ie in movies, or maybe by a holographic projection.
If the light moves in a fluorescent, highly refractive medium, say n=2, the cylinder may probably be seen as motionless by an observer moving at c/2 outside that medium...
1. Is a flat ending light beam physically possible?
Yes, a flat ending light beam is physically possible. It is a type of laser beam that has a uniform intensity distribution across its cross-section.
2. How is a flat ending light beam created?
A flat ending light beam is typically created using a special type of laser called a Gaussian beam. This laser is modified to have a flat intensity profile by using beam shaping optics.
3. What are the applications of a flat ending light beam?
A flat ending light beam has a variety of applications, including in laser cutting and welding, 3D printing, and lithography. It is also used for scientific research, medical treatments, and telecommunications.
4. Are there any limitations to a flat ending light beam?
While a flat ending light beam has many advantages, it also has some limitations. One limitation is that it is more difficult to create and control compared to other types of laser beams. Additionally, the intensity of the beam may decrease over longer distances.
5. Can a flat ending light beam be used for long-distance communication?
Yes, a flat ending light beam can be used for long-distance communication. However, it may not be as efficient as other types of laser beams due to its potential decrease in intensity over longer distances.
  • Science Fiction and Fantasy Media
  • General Discussion
