- #36
votingmachine
- 296
- 84
I would not think it necessary. Prove displacement of water.
But if you really wanted. Build a triangular pool with a known volume. Fill it to the brim. Put a triangular ship (known volume and known weight ... just 8.3 lbs less than the weight of the water in the pool) in and measure the height of the ship and the water displaced. Show the weight of the ship and water displaced is the same. Take out 1 gallon. Measure the height of the ship and the water displaced. Show that the weight of the ship and the water displaced differs by the weight of the 1 gallon of water removed prior to displacement. Take out another gallon and repeat.
When you take out the last gallon, the ship is marginally lower. And your equation for the weight of the ship vs the water displaced (or removed prior to displacement) is suddenly unbalanced.
Personally, the unbalanced equation at the end of the sequence is enough for me. But the reality is that the ship is now lower, and a careful measurement will show that.
You could also go the other direction. Start with a gallon of water in transparent container. Use a large styrofoam bucket as your ship. Keep adding weights and measuring the height of the water around the styrofoam. Again you prove displacement. Your "ship" is always floating on a gallon, with the height based on the weight of the water displaced
The fundamental principle is difficult to show at the extreme case, and easy to show for non-extreme cases. I don't quite understand the reason why the extreme case needs proof, when the principle is established and no one needs a ship in a tank that is form-fitting.
