Can a Floating Tensegrity Sphere Support a Mini-City in the Sky?
In summary, Fuller suggested that a mile-wide geodesic sphere could be used to build a floating city. He calculated that the sphere could lift a considerable mass, and hence that 'mini-cities' or airborne towns of thousands of people could be built in this way. However, there is the issue of pressure difference.
Cannon
I came across this online the other day:
As a sphere gets bigger, the volume it encloses grows much faster than the mass of the enclosing structure itself. Fuller suggested that the mass of a mile-wide geodesic sphere would be negligible compared to the mass of the air trapped within it. He suggested that if the air inside such a sphere were heated even by one degree higher than the ambient temperature of its surroundings, the sphere could become airborne. He calculated that such a balloon could lift a considerable mass, and hence that 'mini-cities' or airborne towns of thousands of people could be built in this way. These 'cloud nines' could be tethered, or free-floating, or perhaps maneuverable so that they could 'migrate' in response to climatic and environmental conditions.
I came up with a formula for calculating the mass supported by such a sphere of air (as a function of temperature, height and radius), and just wanted to see if my math checks out.
http://designbyninjas.com/calculation.jpg
Also, since the air pressure is the same inside as out, would there be any feasible way to pressurize such a system?
Do you by chance recall the link to that?
Indeed, a large enough sphere could be used to build a floating city. Also, as a sphere gets bigger the mathematics of heating it up works out to be more and more economical. However, there is the issue of pressure difference. A sphere built to contain even a small pressure difference might need walls so thick it could end up defeating the purpose.
But you don't really need pressure difference or even temperature difference. Just replace the nitrogen in the air inside the sphere with helium. Helium too expensive? Then replace it with hydrogen; but include safety measures so as to avoid super-Hindenburg scenarios.
Not to burst anyone's bubble(pun intended) would anyone really want to live in a floating city that would be an ultimate, and easy, target for terrorists?
Yes!
Alternatively, it could be turned into a miniature Death Star. If fitted with electronic countermeasures and lots of missiles, it could be used to invade enemy territories...
The stress on the shell, due to buoyancy, is quadratic in radius. The cross-section area of the shell, however, given constant thickness, increases linearly. That means, at some point, you'll have to start increasing thickness of the shell linearly with the size. If you start scaling thickness linearly with the size, the mass of the shell goes up as a cube of the size, same as the mass of enclosed air.
In other words, no, it won't work.
Love this discussion, I summarized it on my blog, http://lawoftheair.com. While you mention the density and defense issues, you leave out low oxygen and the COLD.
1. What is a floating tensegrity sphere?
A floating tensegrity sphere is a three-dimensional structure composed of struts (bars) and tension elements (cables or wires) that are held in equilibrium through the balance of compressive and tensile forces. This unique design allows for the sphere to appear to float in the air, as the tension elements hold the struts in place without any external support.
2. How does a floating tensegrity sphere work?
A floating tensegrity sphere works by evenly distributing forces throughout its structure. The struts and tension elements are arranged in a specific way so that the compressive forces are transferred to the tension elements, which then hold the structure in place. This allows for the sphere to maintain its shape and appear to float in space.
3. What are the advantages of using a floating tensegrity sphere?
One advantage of a floating tensegrity sphere is its lightweight and efficient design. The use of tension elements allows for a strong and stable structure while using fewer materials. Additionally, its unique design can be used for various applications such as architecture, robotics, and space exploration.
4. What are the challenges in constructing a floating tensegrity sphere?
The main challenge in constructing a floating tensegrity sphere is achieving the delicate balance of forces between the struts and tension elements. The structure must be precisely designed and assembled to ensure that the compressive and tensile forces are evenly distributed. Additionally, the materials used must be strong enough to withstand these forces without breaking.
5. Are there any real-life examples of floating tensegrity spheres?
Yes, there are multiple real-life examples of floating tensegrity spheres. One notable example is the Eden Project in Cornwall, England, which consists of several large floating tensegrity domes that house a variety of plant species. Another example is the Moon Habitat prototype designed by NASA, which utilizes tensegrity structure to create a lightweight and adaptable living space for astronauts on the moon.
  • Astronomy and Astrophysics
  • Earth Sciences
  • General Discussion
