Floor Loading of a structure .
  • Thread starter Saint.V8
  • Tags
    Structure
In summary, the designer is trying to figure out how to calculate the floor loading for a structure that has a total weight of 1.6 tonnes and a floor area of 8m x 3.5m. The first calculation will always give the average over the whole room, but pressure won't be uniform over the whole surface. The stress model shows that for the load the structure has to withstand, the material sizes can't be reduced.
Saint.V8
Been trying to bend my head round something that is no doubt so simple it is unreal...!
I am designing a structure that has a total weight of 1.6 tonnes (1600kg), the structure floor area is 8m x 3.5m and sits on 8 pads of 500mm x 500mm.
To calculate the floor loading do I:
Divide the weight by the floor area i.e (1600 x 9.81) / (8 x 3.5) = 560.6 N/m2
or
Divide the weight by the total floor area of the pads i.e. (1600 x 9.81) / ((0.5 x 0.5) x 8) = 7848 N/m2
It is driving me nuts, any help is a massive step forward!
Neither.
The force on the individual pads will depend on the weight distribution of the structure, the positions of the pads and some more details of the setup. In the ideal case, all 8 pads get the same force and apply it uniformly to the ground, then the second calculation gives the pressure at the pads.
Many thanks for the reply, I thought as much that it may be neither of those solutions.
I attach some diagrams of the structure to give a better understanding of the question. In the question above I used roughly generic figures, the images show the final dimensions.
It has to be located in an area with 3.35kN/m2 maximum floor load...
The stress model shows that for the load the structure has to withstand I cannot reduce the material sizes to lighten the structure and it is coming in at the 1.6 tonnes mark as it is!
Hope the images give a better indication.
So ~7m^2 for most of the load. At least the total load looks fine, but don't rely on that. And single pads could still lead to issues.
Further too...
Used the simulation software to tell me the reaction forces, then using the area of each pad on the reaction forces to give me the floor loading force.
2 images attached, one with the original 0.5m square pads and one with 1m square pads under the 'heavy' end...whilst the smaller pads on the end of the structure are over the imposed floor loading limit of 3.35kN/m^2, I can make the pads larger at that end to compensate...my only issue now is from a 'form' point of view...doesn't look very pretty with dirty great steel pads on the floor!
Ho hum, the scourge of the designer...form/function etc.!
Thanks, to all for letting me be parts of this form.
1. What is floor loading of a structure?
Floor loading refers to the maximum amount of weight that a structure's floor can support without causing damage or structural failure.
2. How is floor loading calculated?
Floor loading is calculated by dividing the total weight of the structure and its contents by the total area of the floor. This gives the weight per square foot or square meter that the floor can support.
3. What factors can affect floor loading?
The design and construction of the structure, the type of materials used, the type of flooring, and the intended use of the space can all affect floor loading. Environmental factors such as temperature and humidity can also play a role.
4. How much floor loading is considered safe?
The safe floor loading limit depends on the type of structure and its intended use. Generally, commercial or industrial buildings have a higher floor loading limit compared to residential buildings. However, it is important to follow building codes and guidelines to ensure the safety and stability of the structure.
5. What can happen if the floor loading limit is exceeded?
If the floor loading limit is exceeded, it can cause damage to the structure such as cracks, sagging, or collapse. This can also lead to potential safety hazards for occupants and can result in costly repairs or even building failure.
  • General Engineering
9K
9K
18K
  • Precalculus Mathematics Homework Help
  • Mechanical Engineering
