Flow in an Air Ringmain System
In summary, the conversation discusses the flow velocity in an air ringmain piping system, specifically addressing whether the flow velocity decreases every time it passes an outlet and if the outlet is open or closed. It is mentioned that there are numerous outlets with flow control valves that can increase the flow by induction. The person asking the question is concerned about the furthest outlets not receiving enough flow, but it is clarified that the flow can be adjusted at each outlet to meet the user's requirements.
1988ajk
Hi All,
Quick question about the flow velocity in an air ringmain piping system. does the flow velocity in the ringmain pipe decrease every time it passes an outlet?
Is the "outlet" closed or open?
there are numerous outlets which each have a flow control valve (an orifice)
So, in principle flow can be increased by induction going past an open "outlet?"
Apologies for the late reply.
Yes, the flow can be adjusted at each outlet to suit the users requirements. I have to provide the same flow at each outlet around the ring main system, my worry is that the furthest outlets from the compressor won't receive enough flow.
1. What is an air ringmain system?
An air ringmain system is a closed-loop piping system that uses compressed air to transport materials or fluids. It is commonly used in industrial settings for applications such as pneumatic power, ventilation, and cooling.
2. How does flow work in an air ringmain system?
In an air ringmain system, flow is controlled by pressure differentials between the supply source and the end-use points. Compressed air is pushed through the system by a compressor, and valves and regulators are used to adjust the flow rate at different points along the system.
3. What are the advantages of using an air ringmain system?
There are several advantages to using an air ringmain system, including: versatility, as it can transport both solid and liquid materials; energy efficiency, as it requires less energy to move materials compared to other methods; and ease of maintenance, as the system is self-cleaning and does not require frequent repairs.
4. How is flow rate measured in an air ringmain system?
Flow rate in an air ringmain system is typically measured in cubic feet per minute (CFM) or cubic meters per hour (m3/h). This can be measured using flow meters, which are typically installed at key points along the system.
5. What factors can affect flow in an air ringmain system?
Several factors can impact flow in an air ringmain system, including: pressure differentials, pipe size and length, obstructions or blockages in the system, and changes in temperature. Proper design and regular maintenance can help mitigate these factors and ensure optimal flow in the system.
  • Mechanical Engineering
