Flow Rate Problem: Solve for Time to Pour 6L SAE 10 Oil
In summary, the conversation was about a problem involving calculating the flow rate of SAE no. 10 oil through a funnel with specific dimensions. The participants discussed the pressure difference, flow rate equation, and possible calculation errors. After identifying and correcting the errors, they were able to determine the correct time it would take for the oil to flow through the funnel.
mparsons06
61
Flow Rate Problem - Please Help!
1. Homework Statement :
SAE no. 10 oil has a viscosity of 0.2 Pa· s. How long (in sec) would it take to pour 6 liters of oil through a funnel with a neck 12 cm long and 2.6 cm in diameter. Assume that it is poured in such a way that the oil level is kept just above the top of the tube.
Hint: The specific gravity (= ratio of its density to that of water) of the oil is 0.70.
The pressure difference is given by
Dp = rgL
1000 liter = 1 m^3 = 10^6 cm^3
The flow rate is given by Poiseuille's law:
Q = p * r^4 * Dp / 8*h*L
You can calculate the pressure difference:
Dp = rgL
Dp = (700 kg/m^3)(9.81 m/s^2)(0.0012 m)
Dp = 82.4 Pa
And the time it takes for the oil to flow through is the volume of the oil divided by the flow rate:
t = V / Q = 8 * V * h * L / (p * r^4 * Dp)
t = 8 (0.006 m^3)*(0.2)*(0.012 m) / p * (0.5)*(0.013 m)^4 * (82.4 Pa)
t = 8.97 X 10^-9
But I know that can't be right. Can someone please help me with where I went wrong? And try to explain it to me?
I found two errors.
Dp = rgL
Dp = 82.4 Pa
12 cm is not 0.0012 m.
t = 8.97 X 10^-9
I agree with the next-to-last line here, except for the pressure which you must recalculate based on my earlier comment. Even so, something went really wrong in calculating that final value for t here. Everything to the right of the "/" here is in the denominator, i.e. you must divide by all of those values. Technically, those terms should be enclosed in a pair of parantheses, so that you have
t = 8 (0.006 m^3)*(0.2)*(0.012 m) / (p * (0.5)*(0.013 m)^4 * (82.4 Pa))
It's encouraging that you thought about your answer and realized something is wrong :smile:
Dp = rgL
Dp = rgL
Dp = 82.4 Pa
t = 8.97 X 10^-9
"You can calculate the pressure difference:
Dp = rgL
Dp = 82.4 Pa"
=> r = 700 kg/m^3 ? I'm confused ?
Dp = rgL
Dp = 82.4 Pa"
The density of the oil is 0.70 times that of water, which is 1000 kg/m^3.
t = 8 (0.006 m^3)*(0.2)*(0.012 m) / [ p * (0.5)*(0.013 m)^4 * (82.4 Pa) ]
t = 8.97 X 10^-9
I don't know what "p" is. Help?
p is π here, 3.14159...
So I calculated the equation using pi:
t = 8 (0.006 m^3)*(0.2)*(0.012 m) / [ pi * (0.5)*(0.013 m)^4 * (82.4 Pa) ]
t = 1.9492 sec
But it is still incorrect... Any ideas?
Dp is not 82.4 Pa. See post #2.
Dp = rgL
Dp = (700 kg/m^3)(9.81 m/s^2)(0.12 m)
Dp = 824 Pa
t = V / Q = 8 * V * h * L / (pi * r^4 * Dp)
t = 8 (0.006 m^3)*(0.2)*(0.012 m) / (pi * (0.5)*(0.013 m)^4 * (824 Pa))
t = 0.1949 sec
It is still incorrect.
Hmm, now that I look more carefully I am seeing several problems with the calculation.
1. The numbers you have do not give 0.1949 s
2. 12 cm is not equal to 0.012 m.
3. Where does the (0.5) come from?
So if I recalculate, fixing my errors and taking out 0.5:
t = 8 (0.006 m^3)*(0.2)*(0.12 m) / (pi * (0.026 m)^4 * (824 Pa))
t = 0.974 sec
Still wrong.
1 more try: 0.026 m is the diameter; the radius is 0.013 m. Use the radius here.
You were right! Thank you for helping me out!
Could you please check out my question on Height of Blood Transfusion? Thanks.
What is the flow rate of the oil?
The flow rate of the oil is not given, so it must be calculated using the given information.
What is the volume of the oil to be poured?
The volume of the oil is 6L, as stated in the problem.
What is the viscosity of the oil?
The viscosity of the oil is given as SAE 10, which is a measurement of its thickness or resistance to flow.
What is the unit of measurement for time?
The unit of measurement for time is not specified, so it can be assumed to be in seconds, minutes, or hours.
What formula is used to solve for time?
The formula used to solve for time is time = volume / flow rate. In this case, the formula would be time = 6L / flow rate.
