• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Flow speed
  • Thread starter MAPgirl23
The horizontal pipe has a cross-sectional area of 40.0 cm^2 at the wider portions and at the constriction. Water is flowing in the pipe, and the discharge from the pipe is 6.0 x 10^-3 m^3/s (6.0 L/s).
a) Find the flow speed at the wide portion.
b) Find the flow speed at the narrow portion.
c) What is the pressure difference between these portions? 1.69×104 Pa
d) What is the difference in height between the mercury columns in the U-shaped tube? 12.7 cm
How do I find a and b knowing c and d?
** So far I now:
v1A1 = v2A2
v2 = A1/A2 x v1
By applying the principle of conservation of energy:
p +(0.5*rho*v1^2) + rho*g*y1 = p + (0.5*rho*v2^2) + rho*g*y2
FredGarvin
How can the pipe have the same cross sectional area at the constriction and the wide portions? Where is the constriction? In the middle of the pipe? At the end of the pipe?
65
http://mb.sparknotes.com/mb.epl?b=113&m=1067136&t=306821&w=1 [Broken]
Doc Al
Mentor
44,803
1,061
** So far I now:
v1A1 = v2A2
v2 = A1/A2 x v1
You find a and b before knowing c and d. The volume flow rate is given, as well as the areas of the two pipe sections (at least they are given in your diagram).
65
for part a) v2 = 6.0x10^-3 * (10 cm^3 / 40 cm^3) = 1.50x10^-3 which was wrong
Doc Al
Mentor
44,803
1,061
I'm not sure what you are doing.
Try this: The flow rate (which is given) = V x Area. So, V = (flow rate)/Area. (Be sure to use proper units.)
65
I converted 10 cm^3 = 1.0 x 10^-5 m^3 and 40 cm^3 = 4.0 x 10^-5 m^3
v = 6.0 x 10^-3 * (1.0x10^-5/4.0x10^-5) = 1.50x10^-3 m/s ?
Doc Al
Mentor
44,803
1,061
Good.
Not good.
Why are you taking the ratio of the two areas? Realize that the flow rate has units of volume/sec, while speed has units of distance/sec. So, if you checked your units (always a good idea) you would see that this equation cannot hold.
See my last post for an equation for speed (V) in terms of flow rate and area.
Related Threads for: Flow speed
  • Posted
  • Posted
  • Posted
  • Posted
17K
  • Posted
20K
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
