• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Fluence Calculations?
Summary: Need to calculate the fluence of Gaussian Laser Beam: laser tip 1 cm above surface, tilted at 45 0 angle to surface.
Laser tip size 1 mm across
Diameter 0.5 mm
Surface area = pi r 2
3.14 x (0.5)2
0.79 mm 2
= 0.0079 cm 2
Beam diverts 6 degrees both sides of tip
tan 6 0 = 0.11 cm (base of triangle)
Triangle surface = 1/2 x base x height
= 0.055 cm 2
Total surface = (0.055 cm 2 x 2 ) + 0.0079 cm 2
= 0.1179 cm 2
45 0 angle: cosin 45 0 = 0.707
Total surface 0.1179 cm² ÷ cos 45°
= 0.17 cm²
Pulse Energy = P(average) ÷ Pulse Frequency
= 0.5 W ÷ 30 Hz
= 0.01667 J
Fluence = Energy of laser pulse / Area of spot
= 0.01667 J / 0.17 cm 2
= 0.0980 J/cm² ( area is irradiated for 30 seconds)
( do I multiply ?? x 30 s)
= 2.94 J/cm² (??)
Fluence = (average power) / rep rate/ spot area
= 30 Hz / 0.17cm^2 x 0.5 W
=88.24 J/cm^2 ( ??)
Please help!
9,112
A sketch would help.
This is not high energy physics. As it looks like a homework problem I moved it there.
Trust you can open the sketch
9,112
Thanks.
I don't understand the area calculation (at 90 degrees). Shouldn't it be a circular spot with a diameter of 1mm + 2*1.1mm?
There is a higher order effect from the combination of the 6 degree divergence and the 45 degree angle that increases the area, but that is probably small.
All Js should be J/s.
Want to reply to this thread?
"Fluence Calculations?" You must log in or register to reply here.
Related Threads for: Fluence Calculations?
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
