Fluid Density
  • Thread starter chara76
chara76
A 2.0 kg iron block is suspended from a spring scale and is submerged in a fluid of unknown density. The spring scale reads 2.55 N. What is the density of the fluid?
Buoyant force = mass*gravity
Buoyant force = (Density of fluid)*(volume of iron block)*(gravity)
2*9.81=(density)*(volume)*9.81
I can't figure out how to get the volume to solve for the density.
Answers and Replies
Cyosis
1,495
The equality you've written down claims that the block is floating in the liquid. Don't forget the block is attached to a spring which exerts an upward force on the block as well. Secondly you know that the buoyant force is equal to the weight of the displaced volume. Since the block is fully submerged that volume must be the same as the volume of the block.
chara76
So,
Buoyant force + 2.55 N = (mass)*(gravity)
Buoyant force = 17.07 N
17.07 N = (density)*(17.07 N)*9.81
density=.101937
Is this right?
Cyosis
1,495
No you plugged the value for the buoyant force into the volume of the buoyancy equation in your last step. You will need to find the volume that is displaced by the block, which is equal to the volume of the block because it is emerged in the fluid. Hint: look up the density of iron.
Suggested for: Fluid Density
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
