Fluid Dynamics Forces: Steady, Pressure-Driven Flow Between Parallel Plates
In summary, the conversation discussed the problem of finding the velocity of a steady, pressure-driven flow between two parallel plates, one stationary and one moving. The equations used were the Navier-Stokes equations for incompressible Newtonian fluids and the continuity equation for fluid dynamics. The solution involved solving for the velocity profile, which was found to be a combination of a parabola and a straight line. The force per unit area on the upper and lower plates was also calculated using the shear stress equation. The conversation also addressed a mistake in the original derivation and clarified the physical reasoning behind the velocity profile.
quickdry
I would really appreciate any help with this problem. I'm pretty stuck.
An incompressible viscous fluid occupies the region between two parallel plates. The lower plate is stationary and the upper plate moves with a velocity u. Find the velocity of a steady, pressure-driven flow between the plates. Sketch the velocity profice and consider separately the cases where the pressure gradient is positive or negative. Compute the force per unit area on the upper and lower plates.
most likely navier stokes for incompressible Newtonian fluids found at http://en.wikipedia.org/wiki/Navier-Stokes_equations
and continuity equation for fluid dynamics, found at http://en.wikipedia.org/wiki/Continuity_equation
If the upper plate is taken to be moving in the x-direction, then (velocity) Vy = Vz =0.
With the continuity equation, d(rho)/dt becomes zero as the fluid is incompressible so density never changes. WHere U is fluid velocity, Continuity becomes del(dot)(rho*u) = (del(rho))(dot)u + rho(del(dot)u). (del(rho))(dot)u is zero due to incompressibility as well, so this gives dUx/dx + dUz/dz = 0.
Vz is 0 at the bottom and top plate and thus everywhere else. so Vz=0, dUz/dz=0, dUx/dx=0 by symmetry
so Ux is a function of z. Ux=Ux(z)
WIth the navier stokes equation becomes
0=-dP/dx+μ((d^2)Ux/dz^2)
integrating both sides gives
dUx/dz=1/μ *dP/dx *z + C
Ux(z) = 1/2μ * dP/dx Z^2 + C(1)z + C(2)
Applying the boundary conditions: Ux(0)=0 -> C(2)=0
Ux(h) = V0 -> C(1)=V0/h-1/2μ*dP/dx*h
After this I'm not sure about the pressure gradients part or the forcer per unit area on the plates. I'm not even completely sure I did the flow velocity (Ux(z))) part correctly. Any help would be really appreciated.
I also hope you can understand what I wrote, it's quite hard to type these formulas.
Thanks
Have your read the https://www.physicsforums.com/showthread.php?t=8997" for this forum? It's an easy way to display mathematical formulas.
Seems correct. Now, rearrange it to get,
[tex] U_x(z) = \frac{z(dP/dx)(z-h)}{2 \mu} + V_0z/h [/tex]
How will the plot of U_x(z) vs z, look when dP/dx is positive or negative? If you want, you can put numbers and check the plots.
Now that you've got the velocity profile, and you know that the shear stress is [tex] \mu \frac{dV}{dz}[/tex], can you calculate the forcer per unit area on the plates?
Thanks a lot!
So the force per unit area on the upper plate would be
[tex]\frac{1}{2}(dP/dx)h+\frac{muU}{h}[/tex]
and on the lower plate, it would be
[tex]\frac{muU}{h}-\frac{1}{2}(dP/dx)h[/tex]
If i haven't made a mistake
However, I still have a question about the velocity profile. When plugging in arbitrary numbers, the profile changes drastically depending on the μ value in the positive dP/dx case. With a small μ, the velocity can suddenly become negative between the plates. With the negative dP/dx case, the flow increases in the Z direction as expected, but then suddenly slows when z=h at the top plate. If the top plate is causing the movement of the fluid, then the flow velocity should be greatest at the top plate (z=h). The physical reasoning velocity profile is of a 0 fluid velocity at the bottom plate (Z=0) increasing linearly to a velocity V=U at the top plate (Z=h). Neither of these cases match. The only thing I can think of is if my original velocity equation is wrong.
How did you get that? For example, if you want to find the stress at the lower plate, evaluate [tex]dU_x/dz[/tex] at z=0, and multiply it with [tex]\mu[/tex]. Can you take it from here?
Interesting, isn't it? And it's true!
Consider the equation,
[tex]v_z = \frac{z(dP/dx)(z-h)}{2 \mu} + V_0z/h [/tex]
The first term, [tex] \frac{z(dP/dx)(z-h)}{2 \mu}[/tex], is a parabola, and the second term, [tex] V_0z/h[/tex] is a straight line. When dP/dx is positive, notice that they have opposite signs. The final answer will be a superposition of these two.
No, that's not right.
The linear increase will take place only when the pressure gradient is 0.
haha, sorry, I actually did this but I made a stupid mistake in derivation mixed with messing up how to use "Latex". I have an answer that makes more sense now.
I think I understand the velocity profile now too.
Thanks a lot for your help, I really appreciate it.
What is fluid dynamics?
Fluid dynamics is the scientific study of the movement of fluids (liquids and gases) and the forces that act upon them.
What are the main forces involved in fluid dynamics?
The main forces involved in fluid dynamics are pressure, gravity, and viscosity. Pressure is the force exerted by a fluid on an object, gravity is the force that pulls a fluid downward, and viscosity is the resistance of a fluid to flow.
How does fluid density affect fluid dynamics?
Fluid density plays a critical role in fluid dynamics as it determines the weight of the fluid and affects its ability to flow. Heavier fluids, such as water, will exert more pressure and require more force to move compared to lighter fluids, such as air.
What is Bernoulli's principle and how does it relate to fluid dynamics?
Bernoulli's principle states that as the speed of a fluid increases, its pressure decreases. This principle is important in fluid dynamics as it explains the relationship between flow velocity and pressure in a fluid.
What are some applications of fluid dynamics in real life?
Fluid dynamics has many practical applications, including in the design of airplanes, cars, and ships to improve aerodynamics and fuel efficiency. It is also used in weather forecasting, understanding ocean currents, and designing water and sewage systems.
  • Mechanics
