Fluid Dynamics: Find the Pipe Radius at Height Increase
In summary, The problem involves water flowing through a pipe with a constant speed of 15 m/s and a radius of 4 cm. The pipe then increases in height by 3 m with no change in pressure or speed. The question is asking for the new radius of the pipe at this elevated height. Using the continuity equation and Bernoulli's formula, the new radius is found to be 4.3 cm.
student 1
76
Water is flowing through a pipe of radius 4 cm with a speed of 15 m/s The pipe increases 3 M in height with no change in pressure or speed. What is the radius of the pipe in cm at this new height?
P1+1/2[tex]\rho[/tex]V12+[tex]\rho[/tex]gY1=P2+1/2[tex]\rho[/tex]V22+[tex]\rho[/tex]gY2
The rho's are not exponents they just appeared like that.
A1V1=Constant
I know since I have the radius and speed I can find the Flow rate using the continuity equation. (.04)2[tex]\pi[/tex](15 M/s) = .075 m3/s
The Pi should not be an exponent either. Sorry
Since I have the flow rate I do not know what I should do to relate the rise of 3M in height with Bernoulli's equation. I know since they have the same speed density and pressure; most of the factors will cancel out. Am I missing an equation that could help me out??
Are you sure that shouldn't read there is no change in pressure or mass/volume flow? If there is a change in elevation then there either must be a change in pressure and/or a change in velocity.
No, the problem states that there is no change in pressure or speed. With that being said I assume since the Pipe has changed elevation the Pipe has to change the radius to accompany the fact that there is not a change in the pressure or speed. The Answer is supposedly 4.3 cm, but I have no clue how to get that. I'm sure I have to relate the potential energy of the higher pipe to the original starting location but I don't Know what formula I should use or even if this will help me.
Well, I know you are suppose to pretend the pipe does change and find the change in velocity that would occur for the pipe. Then change the pipe's radius to allow for the speed of the water to flow the same as the pipe on the ground, Any help with this problem please!
You need to use the Continuity equation Flow Q = A1v1 = A2v2 = A3v3 ...
You have already found A1v1 (.075 m3/s)
The velocity v1 = v2 = 15. Note this should be call velocity head because overall velocity does change due to change in area.
Now you need to find Z1 – Z2.
Then you can find v2 and hence A2.
This problem doesn't make any sense. Maybe I'm overthinking it, but you cannot just use continuity. If you use continuity, then the problem is just as simple as
[tex] (\rho A V)_{in} = (\rho AV)_{out} [/tex]
However, this that's assuming that there's only one unknown, A, meaning that the velocity is unchanged (which the problem states). HOWEVER, this means that you can directly solve for [tex]A_{out}[/tex] without taking into account the change in elevation.
Simply put, conversation of energy states that a change in elevation will cause either a change in pressure, velocity, or both.
Minger you had it right. You do have to assume that there is a change in velocity since there is a change in the elevation. However, the way the problem is stated it would not seem that you could do that. So, once you have found the velocity of the second spot 3m above you can use the continuity equation to solve for your radius at the elevated spot.
minger and student 1
The way I see this problem is that we already have a change of pressure (p1-p2) that is causing a flow of 15 m/s. Now we are adding a flow due to the change of elevation.
Because this is a volume flow rate the density and specific weights cancel.
Z1-Z2 = 3-.4 = 2.6m
V2 = 15 – 2.6 = 12.4
Then A2 = A1v1/v2 = 4.3cm which is the answer provided by student 1.
student 1 By Bern formula you must have a difference in pressure or elevation, or both in this case, to get flow.
PS I see you have posted while I was writing this but I will post anyway.
1. What is Fluid Dynamics?
Fluid dynamics is a branch of physics that deals with the study of fluids in motion. It involves the analysis of how fluids, such as liquids and gases, behave and interact with their surroundings.
2. How is pipe radius related to fluid dynamics?
The pipe radius is an important factor in fluid dynamics as it affects the flow rate and pressure of the fluid passing through the pipe. A larger pipe radius allows for a higher flow rate and lower pressure, while a smaller pipe radius results in a lower flow rate and higher pressure.
3. How do you calculate the pipe radius at a height increase?
The pipe radius at a height increase can be calculated using the continuity equation, which states that the cross-sectional area of a pipe remains constant throughout the length of the pipe. This means that the pipe radius will decrease as the height increases, since the cross-sectional area remains constant.
4. What factors can affect the pipe radius in fluid dynamics?
The pipe radius can be affected by various factors such as the fluid's viscosity, density, velocity, and the properties of the pipe material. These factors can impact the flow rate, pressure, and overall behavior of the fluid within the pipe.
5. Why is it important to consider pipe radius in fluid dynamics?
Pipe radius plays a crucial role in determining the flow rate and pressure of fluids, which can have significant implications in various industries such as engineering, environmental science, and medicine. Accurately calculating and understanding the pipe radius is essential for efficient and effective fluid flow management.
