Fluid Flow Through a Pipe
  • Thread starter oydvoid
Main Question or Discussion Point
Here's my situation:
I have a long pipe with n amount of openings along the top, that have an equal distance apart. At one end of the pipe a constant pressure is applied by a pump, and the pipe has a constant diameter all the way to downstream. I’m trying to find a mass flow rate by changing the hole diameters by a delta, where we assume dn(hole diameter) = dinitial + (n-1)*delta. Is it possible to find a delta such that I can get the same volume flow rate out of each hole?
-JC
Answers and Replies
4,303
Yes, this can be done, depending on the details of what is happening. If the fluid is highly viscous, then viscous friction will determine the pressure variation along the header, and the appropriate hole sizes can be determined. However, if the fluid is inviscid (or nearly so), for equal sized holes, the flows should be uniform. Intermediate cases might require the use of computational fluid dynamics to get an answer.
Related Threads on Fluid Flow Through a Pipe
32K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
