Fluid Mechanical problem
A differential thermocouple with sensors at the inlet and exits of a pump indicates that the temperature of water rises 0.072F as it flows through the pump at a rate of 1.5ft^3/s. If the shaft power input to the pump is 27hp.
Determine the mechanical efficiency of the pump
Answers and Replies
Welcome to the forum.
You have to show an attempt at a solution. Do not just post questions and expect an answer. Show your work and I bet someone will help you.
Thanks
Matt
Related Threads on Fluid Mechanical problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
