How does the melting of ice affect the oil-water interface in a fluid system?
In summary, the part of the cube that is submerged in water has a higher buoyant force than the part that is not submerged. This causes the water level to rise and the top level of oil to rise.
AdityaDev
527
33
A cube of ice is floating in water such that some part of the ice is submerged. Oil is poured on the water.( so water on the bottom, oil on top and ice in between). When the ice melts completely, the level of oil-water interface ______(rises/falls) and the top level of oil ______(rises/falls)
None.
The water level goes up a bit due to the ice cube. Also, the level of oil will also be higher than usual since the ice occupies a part of its volume.
Now, as the ice starts melting,
1)the volume of water increases but the level of water has a tendency to fall as volume of water displaced by ice decreases. <---- But I am not able to draw a conclusion here.
2)the top level of oil has a tendency to fall since the volume of oil displaced by ice decreases. And the the net increase or decrease in level of oil depends on the level of water. <---- I need to know case (1) to answer this.
(answer given: Rises,falls)
The last question you should be able to answer without any reference to the first. What happens to the total volume when the ice melts?
For the first question, try to figure out what happens to the ice cube when you add the oil. What happens to the water surface when the ice melts and there is no oil?
Total volume of water increases. when there is no oil, the level of water can also stay constant because the 2 phenomena:
a] the ice displaces some water due to Archimedes principle. say, from 100ml, of water, the new level due to ice becomes equivalent to 110ml.
b] as the ice melts, the volume displaced by ice decreases so the level of water decreases.let 10ml of water be added as ice melts completely.
Now there is no change in water level.
Yes,so if you add oil, what happens to the volume of water displaced by the ice cube.
Likes Chestermiller
Yes. Good point. After the oil is added, the amount of the ice cube sticking out of the water will be greater than before the oil was poured.
Chet
Chet
Can you explain this situation? or can you help me figuring out the answer?:smile:
Sure. Let the side of the cube be s, and let f be the fraction of the cube volume above the liquid water surface. In terms of s and f, what is the volume of oil displaced? What is the volume of liquid water displaced? What is the buoyant force on the cube? From a force balance on the cube, what is f equal to?
Chet
Chet
Volume of cube in water = ##(1-f)s^3##
volume of cube in oil = ##fs^3##
Buoyant force due to water = ##(1-f)s^3\sigma_1g##
Buoyant force due to oil =##fs^3\sigma_2g##
Right, so what equation relates those to the weight of the cube?
$$(1-f)s^3\sigma_1g+fs^3\sigma_2g=s^3\rho g$$
OK. So now solve this equation for f. How does this solution compare with the value of f you get when there is no oil on top of the water?
Chet
Chet
$$f=\frac{\sigma_1-\rho}{\sigma_1-\sigma_2}$$ when oil is present
Taking similar situation with f part inside water,
$$f=\frac{\rho}{\sigma_1}$$
In presence of oil, the buoyant force is increased due to buoyant force by oil.
So with oil, the part inside water is lesser.
Actually, to be clear, your first equation for f is the part outside the water, and your second equation for f is the part inside the water.
So, what does this mean with respect to what happens when the ice cube melts? How does the cube melting affect the depth of the water layer?
Chet
Chet
As the ice melts, the volume of water increases, which tends to increase water level and the weight of ice decreases which tends to decrease the water level. But how do I calculate the net effect?
What happens in the case where there is no oil? How does this case differ from the case of the oil in the original and final water levels, respectively?
Let f part of ice be inside
##fV_i\rho g=V_i\sigma g##
So ##f=\sigma/\rho##
So volume of water displaced is ##V_i\sigma/\rho##
So apparent volume of water is ##V+V_ik##, where k is ratio if density of water to ice which is less than 1.
And after I've has melted,
Volume of water is ##V+V_i##
So there is a net rise in water level.
What is the volume of ice below the water surface before the ice melts (in terms of s)? What is the total volume of water that forms when the ice cube melts (in terms of s)? What is the difference between these two volumes?
Chet
In which case? The case where there is no oil? In that case this would be wrong. Note that the ice changes density to the water density when it melts!
The value of k is greater than 1, because density of ice is less than density of water.
So the water level drops.
Chet
V_s volume of ice gives ##V_sk## amount of water, where k is the ratio of density of water to ice. This comes from conservation of mass.
Now I am confused
Here is what I know. Part of ice inside water is ##f=\frac{\sigma}{\rho}V_s.##
You already determined that, before the ice melts, the fraction of ice under the water surface is ##\left(\frac{ρ-σ_2}{σ_1-σ_2}\right)##. So the volume of the ice cube below the water surface before it melts is ##\left(\frac{ρ-σ_2}{σ_1-σ_2}\right)s^3##. The volume of water that forms after the ice cube melts is ##\frac{ρ}{σ_1}s^3##. Part of this melted volume of water goes into filling the void left by the part of the ice cube that was below the water surface. The rest of this volume adds to the depth of the water layer (if there actually is any left over). So from these relationships, is there any left over, and, if so, how much?
Chet
Likes AdityaDev
Chet
Water level does not change.
##mg=V_i\rho_wg##
##V_i=m/\rho_w##
When ice melts, the volume of water formed is same. So no change.
##mg=V_i\rho_wg##
##V_i=m/\rho_w##
That's only if these is no oil present.
Chet
Likes AdityaDev
Chet
Finally... Water level rises when oil is present.
Likes Chestermiller
Thank you sir. I have been sitting on this problem for a day. Thanks to @Orodruin as well.
Now I can study coordinate geometry for a while.
1. What is buoyancy?
Buoyancy is the upward force exerted by a fluid on an object immersed in it. It is a result of the difference in pressure between the top and bottom of the object.
2. How is buoyancy calculated?
Buoyancy is calculated using Archimedes' principle, which states that the buoyant force is equal to the weight of the fluid displaced by the object. This can be expressed as Fb = ρVg, where Fb is the buoyant force, ρ is the density of the fluid, V is the volume of the fluid displaced, and g is the acceleration due to gravity.
3. What factors affect buoyancy?
The buoyancy of an object is affected by its volume, density, and the density of the fluid it is immersed in. Objects with a larger volume and lower density will experience a greater buoyant force in a fluid with a higher density.
4. How does buoyancy relate to objects floating or sinking?
Objects with a greater buoyant force than their weight will float in a fluid, while objects with a lower buoyant force will sink. This is why objects made of materials with a lower density than water, such as wood or plastic, will float, while objects with a higher density, such as metal, will sink.
5. Can the buoyancy of an object be negative?
No, the buoyancy of an object can never be negative. It will always be a positive force, either pushing the object up (if it is less dense than the fluid) or pulling it down (if it is more dense than the fluid).
